i have a 1992 325i and my gas pedal tends to get stuck. when driving the car it is fine but when i come to a stop like at a stop light the gas pedal tends to get stuck and i have to give it a little force before it clicks over and then from there it is fine again. its a 5 speed so its kinda complicated when you have to force the gas pedal over a little few cm before it is soft again. makes it look like i dont know how to drive a stick shift. haha. if anyone has ever had any problems with the gas pedal please let me know. i took it to the shop and they said it could be the butterfly in the throttle body. but to my common sense i'm not that stupid. they told me to adjust the screw from the throttle body so that it will hit my idle cable and that would just make my idle even higher. but if that is the problem please anyone, any answer would be greatly appreciated.!! also can someone send a link for me so that i can maybe disassemble the gas pedal. maybe i just need some lube on the gas pedal??
