BMW Forum - BimmerWerkz.com
BMW Forum - BimmerWerkz.com (http://www.bimmerwerkz.com/forum/)
-   3-Series (E36) (http://www.bimmerwerkz.com/forum/3-series-e36/)
-   -   License Plate Light E26 323i Coupe not working (http://www.bimmerwerkz.com/forum/3-series-e36/license-plate-light-e26-323i-coupe-58868.html)
Ncc1701a 08-23-2008 10:38 AM
HI All,
I have a BMW 323i Coupe 1998. One of my licens eplate lights is not working. I have changed the bulb and checked the fuse. All is OK. I swapped the caddy with the other light and thsi works fine.
This tells me that ther eis no electrical power going to the light.
I am lost I am not sure what to do to get this working
I have also checked the cables, They appear to be OK, no ligh if any rubbing as far as I can see,
Any help would be appreciated.
Thanks
Dan
darkhorse737 08-23-2008 10:42 AM
You wrote: "I swapped the caddy with the other light and thsi works fine."...
<<< correct me if i am wrong... but after you switch caddy and it works, then it is the caddy that is not working... ;)
Ncc1701a 08-23-2008 10:48 AM
OK....let me see if I can elaborate on this..........I took the caddy from the cable connector that was not working and put it into the the scable connector that was working and the who thing lit up like a christmas tree...
When I took the caddy from the side that was working and plugged it into the connector that is not working nothing happened....no christmas lights
I guess this tells me that it is not the caddy that is the problem.
Thanks
darkhorse737 08-23-2008 11:13 AM
ahhh... i misunderstood.
tell me something. what are the wire colors of the working side; and what are the wire colors of the "not working" side, please???
Ncc1701a 08-23-2008 11:41 AM
Both Sets have Brown and Black wires
Thanks
Dan
Mr Gee 12-05-2012 02:59 PM
Had the same problem. After checking for power at faulty light discovered a broken wire at the rubber grommet leading into the trunk hinge. Also noted other wires in need of repair at the same location.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
