4th Cylinder Down! - BMW Forum - BimmerWerkz.com
Old 01-31-2006, 05:08 AM   #1 (permalink)
WarNox's Avatar
4th Cylinder Down!
in my 320i, 6 cylinder, the 4th cylinder is working at well below the level of the other 5, about 15-20%! They found this at bmw but didnt go opening everything up to find out why!
Does anyone know what could be causing this?
thnx!
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 01-31-2006, 02:20 PM   #2 (permalink)
thekid's Avatar
Do you mean a lose of compression?
Old 01-31-2006, 02:21 PM   #3 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
if its loss of compression, it could be a vaccum leak...
Old 01-31-2006, 10:04 PM   #4 (permalink)
WarNox's Avatar
yeah i mean the compression sorry!
if it was a vacuum leak, how would you go about fixing that, something wrong with the valves or..? i've really got no idea, never worked that far into the car!
Old 01-31-2006, 11:27 PM   #5 (permalink)
thekid's Avatar
If it is one cylinder it could be a problem either with cylinder or with the head. Honestly the only way to find the problem is to take it apart. It may be something simple like a vaccum leak... but I am not sure that this is sypmtomatic of a loss of compression in one cylinder (not saying it can't be, just not familiar with it).
Old 02-01-2006, 01:02 PM   #6 (permalink)
Gkamysz is an unknown quantity at this point
I don't understand how a vacuum leak will reduce cylinder compression. Valves, rings, headgasket, and associated items are typical causes of reduced compression.
Greg
97 328iS, Manual, Stock
Gkamysz is offline   Reply With Quote
Old 02-02-2006, 01:07 AM   #7 (permalink)
Ljk619 is an unknown quantity at this point
There are things you can test without taking apart the engine to see if the problem can be found.
First, leakdown test, of course you need the tester, but basically it compresses air into the cylinder then if it is losing 15-20 percent efficiency, then listen for where the air is leaking out of, if it's the valves leaking then you'll either hear it in the intake or the exhaust.
Second, dry and wet compression test, do a dry compression test on all 6 cylinders, at least twice each one, average them out see if there's a difference, then put about a teaspoon of oil down each cylinder then do the compression test again, if after you put the oil in the compression on the "bad" cylinder averages out with the rest, then you're looking at piston rings.
Both tests require some time and of course the right tools, and of course in the end if either the valves, piston rings, piston, or whatever is actually bad then you will end up doing a tear down of the engine, BUT if you can do these tests yourself CORRECTLY(and i do stress that you do diagnose your car correctly) you'll save up on diagnostic fees that either the dealership or any shop will charge you. Of course if you diagnose incorrectly and they just replace that certain part you think is bad then you're out of luck my friend.
Goodluck with whatever you do.
Ljk619 is offline   Reply With Quote
Clutch Has No Resistance...need Help!! SDSUe36 3-Series (E36) 16 04-06-2011 01:48 PM
New Poster -- QUICK HELP! E36 Clutch slave cylinder question Michael Yount 3-Series (E36) 7 01-24-2006 03:31 PM
M3/328 Slave Cylinder Silverstreak 3-Series (E36) 1 02-23-2005 11:39 PM
"Spinning" ignition cylinder LloydM 3-Series (E36) 1 08-30-2004 08:04 PM
