328i tire pressure? - BMW Forum - BimmerWerkz.com
Old 07-27-2004, 09:58 PM   #1 (permalink)
Dave24v is an unknown quantity at this point
i bought my bmw a month or so ago, and the wheels that it came with are not the standard ones. in the book it tells me what the pressures should be if i had 15 inch rims, but not 16's.
does anyone know what the front and rear's should be? estimates would be ok
Dave24v is offline   Reply With Quote
Old 07-28-2004, 12:52 PM   #2 (permalink)
fresh328 is an unknown quantity at this point
I have stock 16's and they should be set at 34 up front and 36 at rear.
<img src='http://img.villagephotos.com/p/2005-3/974768/500bill.jpg' border='0' alt='user posted image' />
fresh328 is offline   Reply With Quote
Old 07-28-2004, 01:16 PM   #3 (permalink)
Threadkiller
bitcore's Avatar
Tire pressure depends on the individual tire you put on the wheel. Read the sidewall for max pressure and put in about 3-5 PSI less than the max rating.
During the winter, put in 5-6 PSI less than the max tire PSI (while the tire is cold. Once you start driving the car in the winter, the tires will heat up, pressure will increase, and you will reach the correct tire pressure)
The goal is to give your tires a level footprint, so the tread wears eavenly and weight is distributed eavently - which translates to better traction & longer treadlife.
You may want a staggered pressure setting, less in the front, more in the rear. This depends on weight distribution on your car, driving style, alignment and other factors and can yield better traction during turns when the weight is shifted to one side of the car, increasing pressure in the tire, etc etc. This is up to your own experimentation.
The book is for the stock tires that they put on the car (not specifically wheelsize, but that is a factor) and a generalization.
Old 07-29-2004, 08:38 AM   #4 (permalink)
thanks guys
Need Tire Recommendation: 328i ThomasCA 3-Series (E46, E90) 4 05-10-2005 09:16 PM
Tire Pressure Monitors chuckie789 1,6,7,8 - Series and Mini Cooper 2 01-12-2005 09:16 AM
Tire Pressure for my new wheels EuroBeem 3-Series (E36) 0 08-25-2004 11:04 PM
318 is tire pressure trjones1 3-Series (E36) 3 07-29-2004 03:46 PM
Tire pressure monitor sensitivity? alotomeat 3-Series (E46, E90) 0 07-21-2004 10:44 PM
