328I Convertible Drivers door hard to open - BMW Forum - BimmerWerkz.com
Old 02-09-2009, 04:37 PM   #1 (permalink)
fireflyer141's Avatar
fireflyer141 is on a distinguished road
It seems that when the door closes the window closes a little bit more to get a good seal. That extra tension is causing the door to be very difficult to open under that condition. Is there a problem with the mechanism or possibly a bent inner door handle? The passenger door does the same thing without the hard to open situation. Any ideas?
Thanks,
Bob
fireflyer141 is offline   Reply With Quote
Old 02-09-2009, 04:47 PM   #2 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
check out page 17 on link below. There is a EM TOP EMERGENCY OPERATION........
This link will also help you repair it......
http://www.bmwmotorsports.org/BMW_docs/converttops.pdf
johnny,
Old 03-08-2009, 10:20 PM   #3 (permalink)
riveryachter's Avatar
riveryachter is on a distinguished road
I have a 1994 325i Convertible. Your problem sounds like maybe it's two different things. Here's why I say this: My passenger side door glass DOES NOT reposition upwards the last .025 inch or so when the door latches. The door glass DOES NOT drop when the door is unlatched. The interior lights don't come on when the passenger door opens, either.
The driver's door glass DOES reposition on latch/unlatch and the interior lights come on BUT... the door unlatches very stiffly (the latch inside or outside seems to take more effort than it should as compared to the passenger side - or to other like vehicles). It sounds like you may have both those issues rolled into one door.
I'm online right now doing research before I crack the door panels loose. I suspect there is a switch, probably attached to or linked to the door latch mechanism. If I'm right and that switch is faulty on the passenger door, that would explain the glass seal/interior light issue.
I'm betting that on the driver's door being stiff to unlatch, there is a door linkage issue, perhaps a bent actuator rod or possibly a piece needing some lube. I would not recommend petroleum based lubes. I will use a silicone based grease if needed. This avoids chemical damage to the plastic parts.
Any help someone can throw my way would be great!
Good Luck!
Riveryachter
riveryachter is offline   Reply With Quote
Exterior Door handle won't open door crynow82 3-Series (E46, E90) 2 03-02-2012 10:57 PM
Hard top for E36 convertible froderickskulldigger Looking For 0 10-19-2005 10:50 AM
Convertible Top Does Not Open 1998BMWZ3 1,6,7,8 - Series and Mini Cooper 8 04-20-2005 12:22 PM
Really Tight Door Handle, Hard To Open...... just_program 3-Series (E36) 12 01-08-2005 10:45 AM
Remote to open/close convertible? justphong 3-Series (E46, E90) 13 08-15-2004 10:45 PM
