| 325TDs Injector Light 1st Post here..
I have a 1996 325tds. The engine was completely redone except for the injector pump. The engine was performing fine but was building pressure due to broken ring. After the installation the injector light comes on and goes off again. There is also a slight hessitation in the rev up process when that happens. Diagnostics software passes on the DME/DDE system. |
