325is Problems - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 10-06-2004, 01:39 AM Thread Starter
NyteRyda's Avatar
NyteRyda is an unknown quantity at this point
Send a message via AIM to NyteRyda
Just wondering if anyone could help me out on fixing my prob?
Sometimes when I am driving in 2nd-4th gear my check engiene light goes on or the car chokes or even dies out but when i push on the gas the car gives a little choke and the problems go away which is weird. Is there something I need to replace? Please help.
<img src='http://img224.exs.cx/img224/3479/nyte4cn.jpg' border='0' alt='user posted image' />
NyteRyda is offline
post #2 of 9 (permalink) Old 10-06-2004, 02:23 AM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
hmmm i wonder if maybe your catylitic is clogged up. not sure. id get it checked out by a pro to be sure
Furious is offline
post #3 of 9 (permalink) Old 10-06-2004, 12:41 PM
vincentwashere is an unknown quantity at this point
Send a message via AIM to vincentwashere
check your throttle body it might be loose
<img src='http://pic15.picturetrail.com/VOL615/2358567/4641837/67358906.jpg' border='0' alt='user posted image' />
vincentwashere is offline
post #4 of 9 (permalink) Old 10-06-2004, 01:13 PM
RJ'sE36ITS's Avatar
RJ'sE36ITS is an unknown quantity at this point
Send a message via MSN to RJ'sE36ITS
[snapback]205795[/snapback]
The Spark plugs may be bad or with carbon built up, clean them.
if you got $60 dollars to spend wouln't be a bad idea get your fuel injection clean at midas or jeffy lube i get my clean up every year at jeffy lube.
RJ'sE36ITS is offline
post #5 of 9 (permalink) Old 10-06-2004, 02:02 PM
Been here a while.
97alpineM3's Avatar
97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all
I'd also say spark plugs... and then say TB... clean that sucker... if that doesnt fix it... perfessional help is needed... sorry to say.. but stuff like that is hard to diagnos unless you have the right equipment and such knowledge...
Good Luck
Les
1997 E36 M3 1990 E30 325i
97alpineM3 is offline
post #6 of 9 (permalink) Old 10-07-2004, 12:37 AM Thread Starter
NyteRyda's Avatar
thanks for all the info guys. i am pretty sure it shouldn't be a problem with my sparks because i just replaced them and clean the insides recently. how could i check if my cat was clogged up and throttle body was loose? i use fuel system/injector cleaners so i don't think it should be a problem with the injectors. also i talked to my auto tech teacher and he said it could be the 02 sensor?? So I took it to my friend's shop and replaced the o2 sensor and the car seems to run a bit better and smoother but i should wait and see if the problem comes up again. hopefully not
NyteRyda is offline
post #7 of 9 (permalink) Old 10-07-2004, 12:40 AM
Retired administrator
triggrhaapi's Avatar
triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute triggrhaapi has a reputation beyond repute
just a friendly reminder, check engine light only comes on when something related to the exhaust/emissions system is not working properly. Between that and your idle issue, I'd say something is loose or your plugs are clogged. Cats clogged would give you problems in all gears, especially coming off the line.
Addicted to Speed Since 1997
triggrhaapi is offline
post #8 of 9 (permalink) Old 10-07-2004, 12:41 AM Thread Starter
NyteRyda's Avatar
vincentwashere: nice smoked cleans on the black bmw. just wondering how did you make them so dark? did ya use vht niteshades?
NyteRyda is offline
post #9 of 9 (permalink) Old 10-07-2004, 12:59 AM Thread Starter
NyteRyda's Avatar
trighappi: good point. my idle and shift points were messed up but after i changed the o2 sensor and test drove the car the idle seemed normal and shift points were pretty smooth.
NyteRyda is offline
Starter Problems 325is e36surge 3-Series (E36) 6 05-23-2005 04:03 PM
94 325is Problems sre2114 3-Series (E36) 23 10-21-2004 04:27 PM
1992 325is transmission + electronic problems danyal711 3-Series (E36) 1 08-13-2004 10:31 PM
Common Problems on 92' 325is Bimmeracin 3-Series (E36) 4 07-23-2004 10:37 AM
