| It could also be, depending on the temp when its cold, the grease in the slider can become clogged it sort of crystallizes over the years & becomes very hard ( especially with low temps ) you can take the window out the sliders clean all the old grease out, if its become silver & sticky its u/s, replace the grease & presto, everything should work again!
good luck Martin
__________________ |
