| 325is motor help I have a 92 325is that over i reved now the car has a rough idle and makes what i think is valve noise. I did a compresion test and every cylinder is good but when i run the car i can disconnect any 1 coil an the car will run the same no matter what coil is disconnected Any help would be greatly appreciated
Thanks |
