325is engine noise - BMW Forum - BimmerWerkz.com
Old 12-06-2012, 11:45 AM   #1 (permalink)
Sam Fuller's Avatar
Car: For sale 95 325is blk on blk 51000
Sam Fuller is on a distinguished road
325is engine noise
Hi All newbie here, I have a 95 325is coupe with a strange engine noise. doesn't sound serious. ( not a valve noise its more like a fuel injection noise ) sounds like a soft dook dook dook as the engine idles. I am trying to sell it and when I show it the people ask about it, I thought it was a normal sound of the fuel injection. I have had other cars that has this sound (Subaru's). I didn't think it was a big deal. Please advise! Thanks in Advance!
Sam Fuller is offline   Reply With Quote
Old 12-06-2012, 11:52 AM   #2 (permalink)
Sam Fuller's Avatar
The car only has 51,000
The car has 51,000 miles on it and runs great! black on black. otherwise all else is great. I can't see it could have any major problems. I have another question. How do I reset the "need service announcement on start-up" I serviced it and I need to turn it off.
Old 12-07-2012, 12:41 AM   #3 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Why do you classify it as a "fuel injection noise"? Where is the sound coming from? Front of the engine, rear, left or right? That will help identify the problem.
As for reseting the service intervals, you have a couple options, first and cheapest is going to the Dealership and seeing if they will reset it for free. Second is purchasing the item you see below off ebay for $15. However shipping for mine took 3 weeks.
Click HERE to see my E36 Blog
Old 12-07-2012, 01:46 AM   #4 (permalink)
Sam Fuller's Avatar
Exclamation
Sound like its from the top pass side and again it does not sound internal engine rattles....it sounds like an intake pulsating sound maybe its normal? Intake leak? I don't know maybe I should have it looked at. I know Mercedes, this is my 1st BMW. Thanks for the reply though.
Old 12-07-2012, 06:07 AM   #5 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Does it kinda sound like a ticking at all? If you have replaced your spark plugs or coil packs recently double check they were tightened to proper torque spec. When they arent spec'd properly they can cause an slight engine tick sound.
Other causes include oil taking to long to reach the lifters which causes the lifters to tick. Being your in California I dont see this one as much of a possibilty.
The one I think it most is, is your VANOS system. What the Vanos does is advanced the timing of the intake cam for optiminal performance. However the unit has seals and a bearing that can go bad. With only 50k miles on it, it shouldnt be going already, but it is possible.
Old 12-07-2012, 09:05 PM   #6 (permalink)
Sam Fuller's Avatar
It is hard to explain. It does not tick like a valve it more like A DOOK, DOOK DOOK. When idle and it gets faster as the RPMs go up.emphasize the "O" sound and soften the "K" no tick. Does the FI make any normal noise? Or is something wrong with mine?
Old 12-09-2012, 10:19 AM   #7 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
The FI isnt supposed to make noise. Mine never has. You could potentially have a misfire because of a clogged injector and thats where the noise is coming from. If you can the OBD system for trouble codes a misfire code would pop up.
Old 12-10-2012, 11:37 PM   #8 (permalink)
Sam Fuller's Avatar
Its not a missfire she runs smooth and has lots of power and no shaking.
Old 12-13-2012, 08:09 AM   #9 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
A misfire won't always cause the car to shake. A misfire can be quite subtle sometimes.
Old 12-14-2012, 11:26 AM   #10 (permalink)
Sam Fuller's Avatar
A miss fire should also turn on the CEL and I have no faults No codes clear
Strange noise coming from engine/ below engine 325isBMW1988 3-Series (E21, E30) 0 04-10-2009 06:39 PM
E39 Weird engine noise/vibration ? What could it be? (ENGINE VIDEO) 528i_tourer 5-Series (E12,E28, E34, E39, E60) 12 03-04-2009 11:59 AM
loud engine noise and check engine light steviebhoy 3-Series (E36) 4 06-04-2004 06:59 AM
exhuast noise - 1992 325is IvanB 3-Series (E36) 10 05-27-2004 09:25 PM
e30 325is engine clicking noise mrpauly 3-Series (E21, E30) 11 05-24-2004 11:38 PM
