325i wont start, bad fuel pump - MFG date 10/94 - BMW Forum - BimmerWerkz.com
Old 10-09-2012, 08:46 PM   #1 (permalink)
sfrench's Avatar
Car: 1995 BMW 325i
sfrench is on a distinguished road
Send a message via AIM to sfrench
Thumbs down 325i wont start, bad fuel pump - MFG date 10/94
The car in question is a BMW 325i with a manufacture date of 10/94 read from the inside of the drivers side door. Well, I shot myself in the foot. I wasn't paying attention and ran out of gas, now my fuel pump seems to be shot. I hear BMW's get air in the fuel pump when it runs dry and the pump goes out...I know, I'm an idiot. That being said...I planned to replace the fuel pump on my own. I removed the rear seat to find not one, but what looks like 2 fuel pumps. Is this the case?! I am a college student and I just can't afford to pay someone to do it. I have attached photos of each pump. The one that's "cleaner" (ie. you can see some yellow) is on the drivers side. The one that wins the "filthy" contest is on the passenger side. I have looked in the forum threads and read that maybe one is not the actual pump...but I wanted to see if I could get some solid clarification. Do I need to purchase two fuel pumps and replace them both?? Please help! Thank you. -Sarah
325i wont start, bad fuel pump - MFG date 10/94-photo.jpg   325i wont start, bad fuel pump - MFG date 10/94-photo2.jpg
sfrench is offline   Reply With Quote
Old 10-10-2012, 01:50 PM   #2 (permalink)
sfrench's Avatar
Car: 1995 BMW 325i
Still need help!
I've figured out behind the driver seat is the fuel sender, and behind the passenger seat is the fuel pump....now, how do I know if the fuel sender needs replacing? I'd rather not buy both if I don't need to.
Old 10-10-2012, 02:31 PM   #3 (permalink)
PicksBimmers is on a distinguished road
sfrench, I have a 94 318i and had to replace fuel pump. Not that hard to do. The unit on drivers side for is only a fuel level sensor and doubt it could be damaged by running out of fuel (probably same thing on your 325). I did not have to change it. Also while doing this job you should change fuel filter just in case. FYI, when installing new pump BMW tech gave me a tip to put lube on rubber seal to make it easier to slide new unit into the tank.
PicksBimmers is offline   Reply With Quote
Old 10-13-2012, 01:14 PM   #4 (permalink)
sfrench's Avatar
Car: 1995 BMW 325i
I got the new pump in and she lives once again! My question is, how far do you have to push the pump in? There are three lips on the pump seal, does it have to go all the way past the third seal??
Old 10-15-2012, 11:19 PM   #5 (permalink)
The plastic ring that screws the pump into the top of the tank. If it gets full threads and you can turn it around full a couple of times to tight, it should be good. If it is not sealed you will smell gas inside the car.
'89 325i will only start bypassing the fuel pump relay and starting fluid jstnjns 3-Series (E21, E30) 1 08-30-2009 01:54 AM
E36 325i Wont Start Sometimes CiscoKid 3-Series (E36) 1 06-02-2009 03:38 PM
E90 Start Problems Fuel Pump?? hawtes335 3-Series (E46, E90) 1 09-18-2008 11:24 AM
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
Fuel Pump-- No Start nrana99 3-Series (E46, E90) 3 06-04-2005 06:22 AM
