| UNDERDOG
I HAVE A 1995 325IC CONV, I HAD THE SAME PROBLEM IT WAS THE WASHER PUMP. WHEN WORKING THE PUMP SHOULD MAKE A HUMMING SOUND. ALSO MAKE SURE YOUR WINDSHIELD WASHER JETS ARE NOT CLOGGED/AND CHECK THE PRESSURE VALVE LOCATED INSIDE THE ENGINE INSULATION PANEL.
WASHER PUMP $34.00 VALVE $6.00
JUS-N-5 |
