325i choking around 2500 rpm - BMW Forum - BimmerWerkz.com
post #1 of 2 (permalink) Old 06-16-2013, 07:22 PM Thread Starter
Shangiskhan is on a distinguished road
Hey guys, new to the forum here. I usually just go through old threads and find what I need but this time Im finally stumped. There are a lot of threads about problems around 2500 rpms but i havent found any like mine.
About a year ago my 325i died on me and would not start. Im not sure if this was the cause but it turns out the drive shaft caught the o2 sensor cable and had its way with it. After replacing the o2 sensor it began shutting off with no warning at all, usually at low idle and usually in a dangerous situation. After replacing the fuel pump and DME relays this problem was solved but then the choking at around 2500 rpm began. The weird thing about it though is that sometimes ill start her up and the car will run like a dream through the whole rpm range, then the second i turn it off again and let it sit for two or three hours its back to the choking and what not. It seems to do this when the DME is in any situation in which is resets. Like It'll run on factory settings until it readjusts and resumes with the choking (is my assumption). I do know that the car came with a performance chip and this was my last suspect. I would get another but I'm concerned about EWS issues.
this is what I've replaced so far
MAF
throttle position sensor
DME - used
idle control valve
checked extensively for vacuum leaks
fuel/DME/o2 relays
Sorry for the long write up but i wanted to squeeze all the background info in here
I've been on this for more than a year now and would be hugely grateful to anyone who could chime in.
Shangiskhan is offline
post #2 of 2 (permalink) Old 06-20-2013, 01:06 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 1 Post(s)
Have you gotten the OBD system scanned for trouble codes? What year is it?
The trouble codes will help identify the problem.
And Follow Me on Instagram @E36M52
Founding Member of the Canyonrot Club! Paint Code #343
| OE M3 Bumper | M3 Mirrors | Max Velocity GTR Lip | Euro ZKW Projector Headlights | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Lord Vader is offline
BMW E36 choking tavax 3-Series (E36) 1 09-22-2010 09:55 AM
1992 325i BLACK ** 5 SPEED MANUAL 6 CYLINDER** - $2500 kmxar15 3-Series (E36) 0 10-10-2008 07:08 PM
Engine revs up to 2500 RPM with a/c on snpower 3-Series (E21, E30) 11 09-25-2007 05:01 PM
325i manual vs. automatic RPM bmwdriver 3-Series (E46, E90) 4 08-29-2004 02:00 PM
95 325i Stumbles around 4.5k RPM JLong 3-Series (E36) 7 07-27-2004 07:16 AM
