323i intermittant starting - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 09-25-2011, 04:59 PM Thread Starter
macca50 is on a distinguished road
My car sometimes goes all day no problems then for no reason she turns over and will not start.I leave her a while then she starts any ideas anybody ?
macca50 is offline
post #2 of 7 (permalink) Old 09-26-2011, 04:59 PM
TC 94' 325i is on a distinguished road
Sounds like it flooding?, although i am not sure how that could happen on FI vehicles. Either that or maybe it is not getting any or enough fuel.
You could try spraying a little starter fluid in the intake when it will not crank over and try to start it to see if it turns over. (I have done it before on my car, turned out i had a bad fuel pump) Although i believe somewhere in the owners manual that it say it is not recommendd.
Also it might be worth into checking all the sensors ie MAF, CPS, and Throttle body (Mass air flow, and Crank position), as well as the fuel pressure regulator.
one last thing i found that could cause that is the DME getting wet from strong storms and automatic car washing, but i think that only affected early models, i believe 94' and earlier.
Hopefully this info will help you, good luck.
TC 94' 325i is offline
post #3 of 7 (permalink) Old 09-27-2011, 11:36 AM Thread Starter
it seems more like immobilers stuck on or some sensor preventing car from starting It is after it warms up, it starts no problem when cold done 10 mile round trip came home now wont start it just turns over.
macca50 is offline
post #4 of 7 (permalink) Old 09-28-2011, 02:40 PM
Well i don't know to much about the immobilizer system other than there are two types, but just guessing here, maybe a bad relay?
post #5 of 7 (permalink) Old 11-28-2011, 02:37 PM
beemergirl is on a distinguished road
I have a similar problem with my '98 318i (stick shift). I can go months without a problem and then have the problem almost every day. I have found that most times, I can start it by depressing the clutch pedal, turning the key fully in the ignition, and then shifting through the gears. More often that not, it just starts as I am shifting randomly through the gears! There have been a few very frustrating times where it has not started for 20 minutes, and then finally, it starts. I have thought that maybe there is a safety switch that is not working properly where you must have the clutch pedal depressed before you can start the car. Anyone know if this is the case?
beemergirl is offline
post #6 of 7 (permalink) Old 11-28-2011, 02:59 PM
Beemergirl,
I think what you are going towards here is the neutral safety switch, basically it prevents the any user from starting the car in gear. I believe it was made standard for all cars starting in 90's to have.
However i am not sure if different makes switch operate differently, for example my moms Toyota Rav4 will not start unless you press the clutch pedal in, yours may not start unless it is in neutral. I am sure your car has a safety switch though.
post #7 of 7 (permalink) Old 11-28-2011, 03:33 PM
Captain... Savvy ?
Jack Dabsy's Avatar
Quoted: 1 Post(s)
Give us the VIN number and we'll sort it for you... ;-)
Eso es todo!
Jack Dabsy is offline
323i Windshield wiper intermittant failure daddymack82259 3-Series (E21, E30) 0 03-19-2009 09:43 PM
Trouble starting my 2000 323i thbodley 3-Series (E46, E90) 2 02-15-2009 10:58 PM
540i intermittant no starter response yrshaik 5-Series (E12,E28, E34, E39, E60) 6 07-04-2008 12:25 AM
89 320i intermittant no start, HELP. yrshaik 3-Series (E21, E30) 6 12-31-2007 05:28 PM
Intermittant Missfires fitz1057 3-Series (E36) 1 09-11-2005 02:36 PM
