| 323ci odd electrical problem then almost shutdown Hi there!
Hope you can give me some guidance and would appreciate it muchly.
323ci 2000 build.
Driving in rain all day, then the stereo starts to turn itself off and then on. The seatbelt light pops up, then the airbag light, then the telltale automatic stability control plus the ABS lights. Thy stay on and the intermittently turn off only to come on again.
The stereo continues to turn on and off now combined with the shutdown of the air con, demisters etc and the headlights dim down also.
What happens next is the car loses accelleration power, takes an eternity to get up to speed from a standing start. Get to the final hill before home, probably a 35 degree and car almost doesn't make the climb. 40 Meters on and the car can hardly get enough power to get into the garage. Turn off the car and try to turn it over again to just the ticking sound and then to virtually zero power. Looks like I was lucky to make it home.
Power down the window and goes down like a snail.
Currently the car won't start, has low battery power but it's there, no ticking of the starter moor at all but thre looks to be enough power to do so.
Question is if this is just a bad battery or alternator or anything else....
Thanks heaps in advance or your time helping resolve this before I start ringing a mechanic. |
