318ti Compact... - BMW Forum - BimmerWerkz.com
Old 07-31-2004, 06:23 AM   #1 (permalink)
swindon_matt_uk is an unknown quantity at this point
Send a message via MSN to swindon_matt_uk
Hello people right a few things:
1. Passenger side window ride out of the seal and has pinched it at the top. I take it a new window seal around the edge will sort this.
2. Seat belt light goes off after a couple of seconds, shouldnt this stay on until the seatbelts are put on?
3. I am having a bit of bother with the fuel guage, it doesnt work and when I wack the dash it comes on, I've had the clocks apart and bent the connectors slightly on the circuit board to maintain a better contact - still the same. I believe its when the flug is moved so I'm going to re-solder the connector on the back of the clocks to see if this helps.
4. Clutch bites right at the last minute - is that meaning its nearly gone?
5. Exhaust rattle, gonna get a garage to look at this, don't think its major, could do with new hangers all round.
I think thats it, anyone have any ideas/comments?
<span style='font-size:14pt;line-height:100%'>-=CheeRS=-</span>
<img src='http://www.swindonmatt.plus.com/sig.JPG' border='0' alt='user posted image' />
swindon_matt_uk is offline   Reply With Quote
Old 07-31-2004, 09:53 AM   #2 (permalink)
Dsking85's Avatar
Dsking85 is an unknown quantity at this point
well, my seatbelt light goes off too. i think it's just a reminder to buckle up. i can't help ya w/ the other things.
<img src='http://img78.photobucket.com/albums/v349/Dsking85/siggy2small.jpg' border='0' alt='user posted image' />
Dsking85 is offline   Reply With Quote
Old 07-31-2004, 10:10 AM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Ok first off... the thing with the window... yes... it would be a good idea.. and it would fix the problem by replacing your weather strip. (the rubber part your window rides on)
The seat belt thing is just a reminder... not a light that stays on untill you have your seat belt on.
I would say buy a new fuel gauge... if that doesnt work.. I would go back to the sending unit... (underneath your rear seats) and check the connections there.. and research it a bit.. and see what is where.. and start replacing stuff... that is the only way to really do it. Sorry.
Unless someone before you has put a newer clutch and or a racing clutch in your car... it shouldnt really bite at the last possible release of the clutch by your foot. I would get that checked out.. it could be a number of things. Could be your clutch going.. could be the pedel... or the linkages between the pedel and the clutch. I'd have it looked at.
Exaust... its probably just a hanger... they come apart all the time... easy fix.
GOOD LUCK!
1997 E36 M3 1990 E30 325i
Old 08-01-2004, 07:59 AM   #4 (permalink)
Yeah, I was wondering if clutch adjustment could be performed?
Thanks very much for the other pointers - I am taking apart the dash later this evening and will re solder, if not its the guage itself - which might cost me!
Old 08-01-2004, 08:11 AM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I think you can pick the actually gauge up for around 100... give or take 20.
Old 08-01-2004, 08:11 AM   #6 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
In other words... I dont think you have to buy another gauge cluster. If that sucker has failed that is your problem.
Fitted Amp And Sub In My 318ti Compact swindon_matt_uk Audio and Electronics 5 02-01-2005 02:09 AM
Fitted Amp And Sub In My 318ti Compact swindon_matt_uk 3-Series (E36) 0 01-31-2005 08:24 AM
318Ti astral_tx 3-Series (E36) 8 08-05-2004 11:28 AM
318ti questions. JSK 3-Series (E36) 8 01-27-2004 07:00 PM
Any one with pics of 318ti Clear Corners & sides cpuken 3-Series (E36) 6 11-22-2003 06:27 AM
