318is Running Slugish - BMW Forum - BimmerWerkz.com
Old 07-11-2005, 12:31 PM   #1 (permalink)
jmvoth is an unknown quantity at this point
I have a 1995 318is that runs perfectly when the engine is cold, however, when it reaches the normal operating temperature, it becomes very sluggish and has no power. Can it be some sort of sensor that is not performing well? Or, could it be something else? I'd appreciate any comments/ideas/suggestions.
jmvoth is offline   Reply With Quote
Old 07-13-2005, 09:14 AM   #2 (permalink)
My first guess would the temp sender this is under the inlet manifold the dealers can check it see if it’s read right. It’s not that easy to change
Old 07-13-2005, 12:29 PM   #3 (permalink)
93 325i's Avatar
Could be O2 sensor. The sensor isn't in effect until the engine reaches normal operating temp. When mine crapped out, i noticed a gradual decline in performance. The check engine light came on eventually, but you'd notice symptoms before the light comes on. Can you tell if your MPG is down?
Complete mod list and pics:
My 1993 325i
Old 07-15-2005, 05:04 PM   #4 (permalink)
Justin318is is an unknown quantity at this point
yea i have the same problem with my 318 and it runs werid and when its hot and i floor it there is a delay from the pedal to the rpm guage
Justin318is is offline   Reply With Quote
Old 07-15-2005, 08:50 PM   #5 (permalink)
allill's Avatar
allill is an unknown quantity at this point
my car has always been the same way. i never figured it out, just lived with it. that's why i just start it and go!
1996 993 cab
1994 e36ic
1990 corrado g60
1975 stingray
2000 deville
1989 b2200 rust bucket (holding on to dear life)
1992 typhoon (gone)
allill is offline   Reply With Quote
Old 07-16-2005, 12:06 PM   #6 (permalink)
NESS is an unknown quantity at this point
Mine has the same delay in acceleration you guys are talking about and sometimes has a rough idle and Im getting 16mpg. My check engine light went off awhile back but a 'check' light still comes on every now and then.
Do you guys think its better to go ahead and replace both 02 sensors if only 1 is bad?
NESS is offline   Reply With Quote
Price For My 318is tagerman 3-Series (E36) 7 06-22-2005 04:30 PM
Falling Back On The 318is Mfarb 3-Series (E36) 13 12-18-2004 06:23 PM
318i vs 318is vs 320i Sabih 3-Series (E36) 18 08-07-2004 12:28 AM
318IS need to know what part BLACK03GT 3-Series (E36) 4 06-15-2004 12:21 PM
E30 318iS vs E36 318iS LondonE30-318iS 3-Series (E21, E30) 16 03-22-2004 01:32 PM
