318is E36 idle prb - BMW Forum - BimmerWerkz.com
Old 07-23-2004, 02:29 PM   #1 (permalink)
AndyBaloch is an unknown quantity at this point
hi there u lot,
i have got a 1993 L reg 318is coupe. when i start the engine when its cold it hesitates and turns off unless if i push the throttle down and rev it up. once its running the idle is around 750 rpm and when its come on normal temperature then rpm goes up to 1000. which doesnt really make sense,
any thoughts????
i was thinking it might be the idle control valve
will appreciate any commets thanks
AndyBaloch is offline   Reply With Quote
Old 07-23-2004, 03:51 PM   #2 (permalink)
p3rsian is an unknown quantity at this point
try cleaning your throttle body and change fuel filter .. i know when i had the same problem this fixed it ... btw i have a 95 318
p3rsian is offline   Reply With Quote
Bmw 318is Wild Idle nobrakese36 3-Series (E36) 2 07-28-2005 02:58 PM
'94 318is Uneven Idle. Check Engine Light On ultraviolet353 3-Series (E36) 8 12-19-2004 11:17 PM
