318is Bolt Patterns - BMW Forum - BimmerWerkz.com
Old 07-22-2005, 08:52 PM   #1 (permalink)
cymorg's Avatar
cymorg is an unknown quantity at this point
Send a message via ICQ to cymorg Send a message via AIM to cymorg Send a message via MSN to cymorg Send a message via Yahoo to cymorg
i have a 96 318is and was wondering where i might find the bolt patterns or measurements or whatever it is i need so i can make sure i order rims that will fit my car!!!
i am also thinking about upgrading to a larger rim, right now i have the 15 inch but i was entertaining thoughts of going to a 17 or maybe even 18 inch. if i dont get bmw brand rims i'll need the measurements/bolt patterns or whatever--- right??
also; will this change in wheels affect my speedometer or have any other on my cars performance?
right now the only reason i want to do it is because it will look cool
cymorg is offline   Reply With Quote
Old 07-23-2005, 04:43 AM   #2 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
5 x 120 bolt pattern, 38mm offset. Your offset can differ by a few mm, but ultimately you need to make sure that the brake calipers don't hit the rim. 17 's or 18's will work, your tires should obviously be low profile.
Changing wheel/tire size affects a lot of things: suspension handling, speedometer, and braking. In general, a lower profile tire will stiffen up your suspension, but a harsher ride as far as bumps go. And the heavier/bigger the wheels, the more braking power is needed to stop the car. Speedometer accuracy is a function of the wheel diameter. To calculate this, go to:
http://www.miata.net/garage/tirecalc.html
Dudesky_E36 is offline   Reply With Quote
Old 07-24-2005, 12:54 AM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
ya like dudesky said... 120 x 5 will work.. u should really go to like tire rack. or somthing of that sort.. and put in the specs of your car.. and it will tell u which rims will fit your car...
-SOLD..
R.I.P Fast 6
Old 07-24-2005, 01:41 AM   #4 (permalink)
cymorg's Avatar
that kinda sucks i had a post on here not long ago complaining about bumps and a rough ride
Old 07-24-2005, 01:53 AM   #5 (permalink)
cymorg's Avatar
what is this 7 x 15 thing? is that just the wheel ive got on it right now?
Old 07-24-2005, 01:37 PM   #6 (permalink)
Yea, that's the stock rim. 7" wide, 15" diameter.
Old 07-24-2005, 07:50 PM   #7 (permalink)
cymorg's Avatar
alright.
i might survive purchasing new wheels.
17" wheels for 318is jamspeed 3-Series (E21, E30) 15 10-05-2005 08:57 AM
318i vs 318is vs 320i Sabih 3-Series (E36) 18 08-07-2004 12:28 AM
oil drain bolt broke grypnon1 3-Series (E46, E90) 4 07-07-2004 07:35 PM
E30 318iS vs E36 318iS LondonE30-318iS 3-Series (E21, E30) 16 03-22-2004 01:32 PM
E46 bolt patterns e36mpower 3-Series (E46, E90) 4 12-12-2003 08:56 PM
