| 318i Water Pump Hung I got a 98 318i . The water pump went out ( I mean out no bearings in front of pump ) and dumped all the water shut it off and hauled it in . now the problem I got the pump loose using the 2 bolts to push it out . BUT the housing came out of the engine and it wont come on out . its loose and you can turn the shaft that pulley bolts too . I sure hope some of you have run into this and can help me out |
