318i Warning lights - BMW Forum - BimmerWerkz.com
post #1 of 14 (permalink) Old 05-07-2004, 11:54 AM Thread Starter
Shudogg's Avatar
Shudogg is an unknown quantity at this point
Aight heres the deal. I have a 1996 318i and ive noticed that the one rear running light and the other side brake light is out. I checked the bulbs and they work but i think the connection is bad or the ground is bad. thats not the issue though. About the same time that happened my airbag light came on. ( red indicatior in the bottom right of clusters). I was wondering if that could have any connection. i dont want to think that it has airbag problems but idont know. i got a dealership to detail it. i dont know if something happened or not. it only has 62,000 miles on it.
ghead
<span style='color:red'>
CLASSIFIED</span>
<span style='color:blue'><a href='
target='_blank'>WHIPLASHDVD.COM</a></span>
Shudogg is offline
post #2 of 14 (permalink) Old 05-07-2004, 12:32 PM
Defector
El Presidente's Avatar
thei airbag light coming on is a common fault. They dealer can fix it for cheap. I would check the actual metal contacts around the bulb and make sure they are clean.
El Presidente is offline
post #3 of 14 (permalink) Old 05-08-2004, 04:02 AM
Method is an unknown quantity at this point
mayb your fuse blew out...
Method is offline
post #4 of 14 (permalink) Old 05-08-2004, 04:46 PM
TeeUp's Avatar
TeeUp is an unknown quantity at this point
i would suspect an open circuit, or faulty contact. if it were a fuse, it should have been out on both sides.
TeeUp is offline
post #5 of 14 (permalink) Old 05-08-2004, 06:36 PM
camnipotent's Avatar
camnipotent is an unknown quantity at this point
Send a message via AIM to camnipotent Send a message via MSN to camnipotent
I thought each side had a seperate fuse. Actually, I'm quite sure. I'll check it out.
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>1998 BMW 323is Coupe, Black
Manual
18&quot; M3 Hyper Silver Rims
2 12&quot; Rockford Fosgate Subs; Sealed
1.0 Farad Capacitor
800 Watt 2-Way Rockford Fosgate Amplifier</span></span>
camnipotent is offline
post #6 of 14 (permalink) Old 05-08-2004, 07:42 PM
TeeUp's Avatar
Originally posted by camnipotent+May 8 2004, 06:16 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (camnipotent @ May 8 2004, 06:16 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-TeeUp@May 8 2004, 04:26 PM
I thought each side had a seperate fuse. Actually, I'm quite sure. I'll check it out. [/b][/quote]
i'm looking at a haynes manual and the only fuse that i can find is the one from front power distribution box between the batteries and the light switch. but there seems none from the light switch all the way to where the wires split - each going to the left and the right rear light assemblies.
i maybe wrong though,,,,,
TeeUp is offline
post #7 of 14 (permalink) Old 05-08-2004, 07:48 PM
TeeUp's Avatar
fuse info from haynes:
brake light switch - F46
parking and tail light switch - F37 and F33
TeeUp is offline
post #8 of 14 (permalink) Old 05-08-2004, 08:14 PM Thread Starter
Shudogg's Avatar
hey thanks, but where are they located-does it give a skimatic (??spelling??)
CLASSIFIED</span>
Shudogg is offline
post #9 of 14 (permalink) Old 05-08-2004, 08:34 PM
TeeUp's Avatar
the fuse box is that black box located on under the hood beside the brake/clutch fluid reservoir. you can flip it open and take out the cover. under the cover is a diagram on which fuse is located where. it should be easy to figure out - you just have to orient the map with how the box appears in front of you. you can actually visually check any blown fuse - better still, use a tester.
oh, there are spare fuses and a tweezer on the cover for easy change. just make sure though that you replace blown fuses with the right amps from your spare.
TeeUp is offline
post #10 of 14 (permalink) Old 05-08-2004, 08:38 PM
TeeUp's Avatar
and while doing that you might want to check the following fuses for your other lights and indicators:
F27
F31
F23
F45
F46
TeeUp is offline
post #11 of 14 (permalink) Old 05-08-2004, 10:38 PM Thread Starter
Shudogg's Avatar
Big help, thanks
i knew where the fuse box was i just didnt know that the layout on the underside of the lid was a map. ill try it tomorrow and well see if it works ( i hope)
maybe this will solve the gauge problem too (another topic)
thanks again
Nate
CLASSIFIED</span>
Shudogg is offline
post #12 of 14 (permalink) Old 05-09-2004, 04:13 AM
Originally posted by TeeUp+May 8 2004, 07:22 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (TeeUp @ May 8 2004, 07:22 PM)</td></tr><tr><td id='QUOTE'>
i maybe wrong though,,,,, [/b][/quote]
You're right. Turns out that I was thinking about the headlights instead of the tail lights. May be the fuse. It shouldn't be hard to spot if it is.
Manual
1.0 Farad Capacitor
post #13 of 14 (permalink) Old 05-10-2004, 08:57 PM Thread Starter
Shudogg's Avatar
hey teeup thanks alot, the # 46 fuse was blown and that fixed the breaklights and the fuel and temp gauges. im having the rest done by the dealer (airbaglight and the inspection LEDs)
thanks again....
nate
CLASSIFIED</span>
Shudogg is offline
post #14 of 14 (permalink) Old 05-11-2004, 12:22 AM
TeeUp's Avatar
no problemo, bro...
you learn some... you share some...
have fun with your ride!
TeeUp is offline
ABS, brake, and ASC warning lights on!? mantoboy 3-Series (E46, E90) 9 02-09-2009 07:54 PM
Anti Lock And Traction Control Warning Lights 2MuchTorque 5-Series (E12,E28, E34, E39, E60) 3 05-12-2005 08:05 PM
1993 Bmw 318i Lights Flickering t1kim 3-Series (E36) 3 04-04-2005 10:24 PM
E36 318i Altezza Style Tail Lights Buddha_318i 3-Series (E36) 12 02-04-2005 06:34 PM
318i - Adding fog/driving lights Maxwell 3-Series (E36) 4 11-25-2003 02:53 AM
