318i Timing Chain Rattle - BMW Forum - BimmerWerkz.com
Old 05-11-2006, 10:16 PM   #1 (permalink)
singring is on a distinguished road
I have a 1995 318i , automatic, 127,000 kms. Last few weeks there is a chain rattle noise occuring from engine area, when car idles from cold start. Once car is revved up, the rattle goes away. I am thinking the timing chain tensioner need replacing. Previous posts indicate this is a very easy, and inexpensive job. I have a Bentley manual, and I will be following it when changing the part. But, I was wondering if the timing chain can be observered with cover off, and engine running. Probably NOT !! So, when I remove the cover, and inspect the chain, how will I know if the tensioner needs to be replaced? Should there be ANY slack in the chain? Anything else I should be looking for?
Thanks
singring is offline   Reply With Quote
Old 05-12-2006, 12:29 PM   #2 (permalink)
Is it REALLY this complicated ??
Well, I quickly looked through the Bentley manual, and contrary to some posts, this is a very involved repair. Is it really necessary to drain the engine oil, drain the coolant, remove the fan and shroud, disconnect the hoses from thermostat housing?? Every post I've seen suggests this is a 10-15 minute job....am I missing something here?
Your advice is appreciated
Thanks
Old 05-12-2006, 01:37 PM   #3 (permalink)
Retired administrator
triggrhaapi's Avatar
it should be fairly easy to get at the tensioner, but beware of oil leaking from the hole if you don't spend the time to do it right.
Addicted to Speed Since 1997
Broken Timing Chain 92 E36 rotaryrex7 3-Series (E36) 1 08-10-2005 11:46 PM
Timing Chain Tensioner Swap, Is It Possible? victorgallas 3-Series (E36) 0 03-29-2005 02:25 PM
Vanos Or Timing Chain Problem? liquidtiger720 5-Series (E12,E28, E34, E39, E60) 0 12-11-2004 08:59 PM
Timing Chain Cover Removal (e36 M3) Jams6502 M-Series (M1, M3, M5, M6) 3 10-06-2004 04:35 PM
1994 318i has a timing belt or chain? jp_bmw 3-Series (E36) 2 09-29-2003 11:53 PM
