| It definitely sounds like the balljoints and/or control arm bushings. If one wears out, usually the other one will follow. It's better to replace in pairs so they wear out evenly.
A worn control arm bushing should just look like deformed rubber. The end of the control arm should look like it's pushing the bushing out of place. You might also noticed cracks around the rubber. These are sure signs the control arm bushing is worn. A good control arm bushing should be properly seated within it's metal carrier. You should be able to see it's round and flat surface.
A worn balljoint is very easy to spot. Just look at the bottom of the balljoint. If it looks like the round metal plate has fallen off or is lose, that's another sure sign the balljoint is worn. It should be tight with no lose moving parts.
Bry
<img src=" http://www.maxbimmer.com/forums/atta...tc=1"> |
