318i M42 timing help please! - BMW Forum - BimmerWerkz.com
Old 01-06-2012, 05:17 PM   #1 (permalink)
Daviid318i is on a distinguished road
i have a 91 318i.. m42 engine.. the head gasket went on it, and im down to the point to where i need to remove the cams to take the head off.. ive never done anything like this before and was wondering if anyone would be able to tell me how to make sure i get the cam gears in the correct place and make sure its timed right.. any help would be apreciated!
Daviid318i is offline   Reply With Quote
Old 01-06-2012, 05:54 PM   #2 (permalink)
Car: 1994 E36 318I
Frozen 318i is on a distinguished road
Cam Gears
Make a mark on the cam and cam gear to make sure you line them up. the thinner the mark the better.
Frozen 318i is offline   Reply With Quote
Old 01-07-2012, 03:00 PM   #3 (permalink)
ncktuley1's Avatar
Car: 92 318is
ncktuley1 is on a distinguished road
There is a special tool that you can buy to line up the cams so they're on TDC. And at the end of the cams, there are two little holes on each one only on one side. make sure those are pointed up when you have the lower end of the block set at tdc. then line the cams up with the tool.
ncktuley1 is offline   Reply With Quote
Old 01-07-2012, 03:24 PM   #4 (permalink)
Car: 1994 E36 318I
Cam Locking tool
I am sorry I should have said something about that you should use the cam locking tool to lock the cams in place, if you are not changing your timing chain you can also remove the head without moving the cams. just remove cam gears and you can make the tool yourself look in the chilton's repair manual the dimensions are there. I made my marks using a nail so the the mark didn't wipe off and the where spot on..for the fly wheel you should buy the tool to lock it on passenger side of oil pan..I set TDC before the head went back on then I put a rod thru the spark plug hole to make sure it stayed that way.
Old 01-07-2012, 05:12 PM   #5 (permalink)
Thank you both. I should be able to handle it from here. Thanks again
Old 01-08-2012, 07:54 AM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
There will be a mark/arrow on the cam-pulley, and a mark on the head...!
Alternatively you could use a tie-wrap (zip-tie) to hold the chain to the cam-pulley.
Remember to set the crank to TDC ;-)
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Replacing Timing chain Tensioner for E36 318i 1994 hyper_cool 3-Series (E36) 0 08-28-2007 04:54 PM
318i Timing Chain Rattle singring 3-Series (E36) 2 05-12-2006 01:37 PM
Timing Settings, 1985 318i? SquireOne 3-Series (E21, E30) 1 03-07-2005 02:58 PM
Timing Belt On 318i csierra 3-Series (E21, E30) 17 02-19-2005 06:22 PM
1994 318i has a timing belt or chain? jp_bmw 3-Series (E36) 2 09-29-2003 11:53 PM
