| [FONT=Optima][SIZE=14][COLOR=blue][B]my j reg bmw 318i looses power at 3500 revs and starts to missfire around 4000 rpm if i ease off the gas then the missfire will clear at around 3000rpm.
The problem is consistant and is the same in all gears, i have changed the ignition coil, leads, spark plugs, distributor cap and rotor arm, tappets, all filters and the oil but still the problem persists does any one have any ideas any help in this area would be much appreciated.
The options i have left are to check the catalytic converter as suggested by a friend or to have a diagnostic test performed which could prove expensive as the obd1 appears not to be working when i have tried the accellerator method.
thank you to anyone who can help as i am getting a little annoyed as you might expect. |
