318i Engine Issue - BMW Forum - BimmerWerkz.com
Old 01-15-2005, 09:06 AM   #1 (permalink)
M3wannabe2004's Avatar
M3wannabe2004 is an unknown quantity at this point
Not sure if any of you can help, my mechanic has run out of idea, wonder if any of you clever guys can help..
This is only when the engine is cold i think, but when the engine is warm it does effect it as well..
Basically when i put my foot on the accelerator the car stutters, it doesn't respond to the pedal straight away, it used to, but now there is a slight splutter then it revs, this is also noticable when the car is warm and trying to pull away quickly, what are the obivous things to check. it's weird and has only been doing it in the last 4 months, the car has just had an oil service, 1 month ago..
Any help would be great.
318i 96, M
M3wannabe2004 is offline   Reply With Quote
Old 01-15-2005, 06:08 PM   #2 (permalink)
318i 96, M
[snapback]272161[/snapback]
Sounds like you're losing backpressure. You might try checking the exhaust pipes for air leaks. Also check all vaccum hoses and the intake boot. Any leaks in the intake or exhaust system will screw up the car computer readings for A/F ratio. It'll definitely make the car sputter and lose power. Does the exhaust smell very rich?
Anyways, when the car is cold, try not to rev it past 3000RPM. It won't run perfectly till it has reached normal running engine temp.
Bry
Old 01-15-2005, 06:11 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Also.. another interesting thing to check.. which was probably checked.. (or atleast I hope) by your mechanic...
Take a look at the condition/type of your spark plugs... make sure they are of the OEM version...
Les
1997 E36 M3 1990 E30 325i
Old 01-16-2005, 03:57 AM   #4 (permalink)
Originally posted by Autotechnica+Jan 15 2005, 06:08 PM--><div class='quotetop'>QUOTE(Autotechnica @ Jan 15 2005, 06:08 PM)</div><div class='quotemain'><!--QuoteBegin-M3wannabe2004@Jan 15 2005, 09:06 AM
318i 96, M
Bry
[snapback]272209[/snapback]
[/b][/quote]
The exhaust does smell rich, where would the vaccum hoses be? thanks for your help..
Old 01-17-2005, 12:43 PM   #5 (permalink)
gt325i is an unknown quantity at this point
318i 96, M
Bry
[/b][/quote]
gt325i is offline   Reply With Quote
Old 01-17-2005, 01:18 PM   #6 (permalink)
HI HOW ARE U DOIN I HAVE THE SAME PROBLEM RIGHT NOW ANY TIPS ON HOW TO FIX OR U DID'NT GET AROUND TO IT.BECAUSE I LIVE IN BROOKYN NY AND TRUST ME U NEED THE SPEED.MY CAR IS STUTTERING THE SAME WAY AN THE EXHUST IS SMELLING RICH THIS PROBLEM DOES NOT HAPPEN ALL THE TIME JUST EVERY OTHER DAY..
Old 01-17-2005, 03:34 PM   #7 (permalink)
[snapback]273342[/snapback]
Hi There! Im just fine, u? My problem is still there, i haven't changed the sparks yet, it's strange, hopefully somebody here will help, what else have u tried?
Old 01-17-2005, 07:07 PM   #8 (permalink)
Originally posted by M3wannabe2004+Jan 17 2005, 03:34 PM--><div class='quotetop'>QUOTE(M3wannabe2004 @ Jan 17 2005, 03:34 PM)</div><div class='quotemain'><!--QuoteBegin-gt325i@Jan 17 2005, 01:18 PM
[snapback]273489[/snapback]
[/b][/quote]
HI.well i changed the park plug but i still have to check my vaccum hoses and leakes in my exhust system etc....good luck with yours and if u get it fix before me let me know what it took.
Old 11-29-2005, 12:36 AM   #9 (permalink)
joeblow4646 is on a distinguished road
Hi guys. I am having the same problem too!!!!!!!!! I have a 94 318i. Any updates? I have no clue why it does that. Kinda annoying. At first, i thought it was the transmission, but after reading this, it makes sense....but still don't know anything about anything -_-.... Thanks!!!!!!!!!!
joeblow4646 is offline   Reply With Quote
Old 11-30-2005, 11:18 AM   #10 (permalink)
Zikonian is on a distinguished road
Greetings from Norway!
I had the exact same problem with my 318i not long ago!
I had a rather serious leak in the exhaust system, about 5-10 cm before the O2/oxygen sensor.
It made the car behave like described in this thread.
If this, or any other airflow sensor/reader is getting bad or no signals, this usually happens!
The engine is an M43 from 1994.
My exhaust had actually broken nearly into two pieces! (my car is well past reasonably low, and it cracked when I drove over a speedbump in the road with four people in the car hehe)
I hope this helps!
Zikonian is offline   Reply With Quote
Old 11-30-2005, 10:05 PM   #11 (permalink)
Thanks Zikonian, I appreciate your reply all the way from Norway!!! I should go check the exhaust and oxygen sensors when I have free time. THanks for the help.
Old 11-30-2005, 10:49 PM   #12 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
check the air mass sensor, then check all ground wires..i had a similar problem, my main ground was loose and my fuel injectors were cutting out....
Old 12-01-2005, 11:28 PM   #13 (permalink)
Thanks Infusion. Appreciate the comments man. How much did it cost to have the repairs done (inspection fee, parts and labor)? THanks dude.
Old 12-06-2005, 12:40 PM   #14 (permalink)
ridikuledind's Avatar
ridikuledind has a little shameless behaviour in the past
I have the same problem with my 1995 318is too. My car also majes a horrible noise that sounds like my clutch fan is rubbing on plastic, but thats not what it is.....
<span style='color:red'><span style='font-size:14pt;line-height:100%'><span style='font-family:Geneva'>&quot;Were coming for you&quot;</span></span></span>
ridikuledind is offline   Reply With Quote
Old 12-06-2005, 01:21 PM   #15 (permalink)
ex owner/admin
Furious's Avatar
ahh cold weather. my car as well used to do that when i drove it in the winter, however its pretty typical of any cold car (any model any make) if the problem goes away when its warmed up than you may not have a problem to be concerned about, just drive the car conservatively untill your car gets to the proper operating temp
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
1999 540i Engine Replacement beachbumm 5-Series (E12,E28, E34, E39, E60) 5 06-20-2005 09:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
will a 325i engine fit in my 318i ? laxinmiah22 3-Series (E36) 11 08-08-2004 02:17 PM
