| ok first things first, you'll want to remove your ps reservoir first and check that for cracks, it's held on by a simple clamp, if that checks out one of your lines is probably leaking and you'll want to check them both to figure it out, clean up the area and pour some fluid in turn the wheel back and forth and see if you can tell where it's coming from, it will be hard to tell with everything covered in fluid already
__________________ 2011 Mazda2
1990 Mazda Miata |
