3 Series Heater Fan Speed??? - BMW Forum - BimmerWerkz.com
Old 01-12-2005, 09:12 AM   #1 (permalink)
M3wannabe2004's Avatar
M3wannabe2004 is an unknown quantity at this point
Hi all, i'm not sure if it's just me but, i have had a few cars in my life and the bmw i have now seems to be the worst for heater controls and fan speeds, im not sure if it's a fault with mine or not, but basically it does seems strange. The car has the following:
-A/C
-Digital Climate Control
When i pump the speed setting to full and only use the front vents it seems the air is only being blown out at the level of a car a manaul control set to about 2!. My mates have other cars and they have also commented, in your opinions is there anything wrong with mine? any checks i can do? or is it just the BMW way. Any help would be greatfully accepted.
Also, I have a strange noise coming from the engine bay at about 3500 rpm, it sounds kinda metallic, like a rattle, but it's the not the engine... any suggestions??
Thanks for the help in advance
M3wannabe2004 is offline   Reply With Quote
Old 01-12-2005, 03:38 PM   #2 (permalink)
Silverstreak is an unknown quantity at this point
Mine is pretty powerful, have you tried messing with teh air vent adjustment controls? Make sure the RED/BLUE wheel adjuster is on the blue side or it will cut the airflow like you are saying.
<a href='http://www.cardomain.com/memberpage/237652' target='_blank'><img src='http://img170.exs.cx/img170/5774/sig2uq.jpg' border='0' alt='user posted image' /></a>
Mods: M50 intake manifold, BFP CAI, Fan delete, CDV delete, Clears all around, M contours, Clutch stop, Debaffled exhaust, CF BMW emblems
Silverstreak is offline   Reply With Quote
Old 01-12-2005, 04:41 PM   #3 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
You might want to look at replacing your In-Cabin microfilter, too.
if it's clogged with crap the blower can't get much air past it.
kestrel325is is offline   Reply With Quote
Old 01-12-2005, 04:52 PM   #4 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
as for the rattle, check your wheel bearings and bushings...also, check the exhaust mounting brackets...all these can cause a metallic rattle at certain RPMs...
Mine was a result of bearings...you wouldn't think so, but thats what the dealer replaced and now the sound is gone.
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12&quot; Alpine Type-R, sealed box
Infinity Kappa 4&quot; 2-way speakers(rear)
Infinity Kappa 5.25&quot; component speakers(front)
Debaffled airbox, K&amp;N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 01-13-2005, 02:39 AM   #5 (permalink)
[snapback]270130[/snapback]
The micro filter was supposed of been replaced no more than a year ago, although I have a sneaky suspician it wasn't, I will check this, thanks mate
Old 01-13-2005, 02:40 AM   #6 (permalink)
[snapback]270140[/snapback]
Well the rattle is apparent at stand still as well, not just when moving, so I guess that rules wheel bearing out, it sounds like it's something on the drive belt, but im shit scared to even go near that!
Old 01-13-2005, 02:41 AM   #7 (permalink)
[snapback]270067[/snapback]
I thought the red/blue just meant hot/cold, it doesn't seem to make any difference what side it's on, the a/c doesn't seem to be that cold either, my mates crappy 1.2 corsa makes your hands freeze in the summer, mine barely cools you down!, any idea on that as well??
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 02:18 PM
Official launch of the BMW 1-series AZ325Ci Bimmer Talk/Motorsports Talk 8 03-29-2004 10:07 PM
Coupe De Grâce: 645Ci Stacy540i Bimmer Talk/Motorsports Talk 15 11-24-2003 06:56 AM
