Originally Posted by CanadianWraith are they really? i was always under the assumption that 2 dr and 4 dr lights were not interchangeable. well you know what happens when you assume  |
Corner lights are different because the coupe has a longer hood by an inch; the width is the same, therefore the headlights are as well.
The fogs are the same since the bumpers are the same across all e36 versions.
