1st Gear Jumpy Under Load..? - BMW Forum - BimmerWerkz.com
Old 08-08-2006, 05:17 PM   #1 (permalink)
API
API is on a distinguished road
I have an E36 320i Coupe and bassically if I pull away under load in 1st gear, it starts jumping back and forth like it really doesnt want to go..., how ever, if i fade the revs in, you know... get going then whack the foot down, it goes right through the Rev Range... Anyone Know Whats Up!?!?!?!?!
Thanks, Adam.
API is offline   Reply With Quote
Old 08-10-2006, 07:28 PM   #2 (permalink)
kylek325i is on a distinguished road
Send a message via AIM to kylek325i
how old is your clutch? if its worn out it will slip under load. does the car jerk when you hammer down the gas at any speed? Then it could be throttle related.
kylek325i is offline   Reply With Quote
Old 08-13-2006, 12:22 AM   #3 (permalink)
polaris448's Avatar
polaris448 is an unknown quantity at this point
i had this happen to me and all it turned out to be was that my air intake ducts had torn due to age(un-metered air will cause jumpy low end)...if one is torn the rest are on their way to being torn. take my advice replace all of the ducts. oh ya a quick fix would be duct tape...i covered mine with electrical tape because i could never open my hood and see duct tape :
polaris448 is offline   Reply With Quote
Old 08-14-2006, 05:18 PM   #4 (permalink)
rej487's Avatar
rej487 has a spectacular aura aboutrej487 has a spectacular aura aboutrej487 has a spectacular aura about
Send a message via AIM to rej487
Ya, it sounds as though it is air related, could be an ignition coil but you'd feel that throughout the whole rev. It could be the worst, a torn subframe but I doubt that. Get your system checked for air leaks, that would be your best bet. Also check out your throttle boot, they're notorious for going bad on these cars.
Good Luck!
1993 BMW 325I - Alpina White
rej487 is offline   Reply With Quote
318ise Jerking/Kangarooing 1st gear MrMasterD 3-Series (E36) 18 08-08-2012 11:52 AM
grinding in 1st and second gear even when clutch is fully pressed?!! SpeedInfusion 3-Series (E36) 8 04-03-2006 06:39 PM
SMG questions... chuckie789 3-Series (E46, E90) 7 08-06-2004 10:55 AM
