1998 323 wont start...electrical - BMW Forum - BimmerWerkz.com
Old 06-15-2004, 10:38 PM   #1 (permalink)
roberts5 is an unknown quantity at this point
Thumbs up
After sitting for 45 minutes my sister's 1998 323is would not start. After I checked it several hours later the battery showed 10V on my multimeter. Figuring it was just a drained battery, I tried to jump it with my other car. When trying to start the car I just get a loud CLICK then nothing. Also it acted a little funny after that. I disconnected the jumper cables, then reconnected and tried again. Same thing. I also noticed that when the key is in ignition position (I still get some power) relays K13 and K21 (i think those are the numbers, I got them off a website) were buzzing and clicking back and forth. ALSO, I'm getting a check engine light, but I dont know how to get the code.
I know cars well, but not BMWs. If anyone has any suggestions I'd be very grateful. Thank you.
roberts5 is offline   Reply With Quote
Old 06-16-2004, 12:02 AM   #2 (permalink)
e36_m3_Turbo's Avatar
could be the starter, but im not 100% sure.
No longer red.
Old 06-16-2004, 05:42 PM   #3 (permalink)
how would i test the starter?
any other ideas?
Old 06-16-2004, 05:45 PM   #4 (permalink)
CiscoKid's Avatar
did you put the + on your battery/+ terminal and ground the -
Old 06-16-2004, 07:11 PM   #5 (permalink)
Threadkiller
bitcore's Avatar
if he didn't there would be a fire, maybe an explosion, or at least some molten jumper cables after 45 minutes of that.....
Check the fluid level of the battery.
Old 06-16-2004, 08:46 PM   #6 (permalink)
Gator is an unknown quantity at this point
The first thing to do is get a new battery. Batteries can act very strangely and I've even had one that died at a gas station and couldn't be jumped. If it only reads 10 volts you will need a new one anyway.If you still have problems with a new battery, then you can start troubleshooting.
Gator is offline   Reply With Quote
Old 07-04-2004, 02:32 AM   #7 (permalink)
FireBlue323IS is an unknown quantity at this point
An even number like 10V, 8V, 6V etc... indicates a bad cell in the battery. Because they are divided into 6 cells normally. I woud take it to a battery shop and have it load tested not charged. Usually they do it for free. Cells sometimes die because they were run dry(no water). Or a short across cells.
FireBlue323IS is offline   Reply With Quote
Old 07-04-2004, 11:32 AM   #8 (permalink)
Defector
El Presidente's Avatar
Thats one thing I love about my capacitor. I can check my voltage level anytime. (usually at 12.4).
Help Buying 98 M3 spy4652452 M-Series (M1, M3, M5, M6) 6 02-13-2005 06:27 PM
Carfax Please: Wbadd632xwbw44671 cpuken 5-Series (E12,E28, E34, E39, E60) 3 12-03-2004 08:04 PM
