power window problem
1K views 7 replies 4 participants last post by  Stunnd65
#1 ·
The button near the shifter for the rear passenger side window is not raising the window but it does lower it. The button on the door raises and lowers the window just fine. Also, the front button is not lit but the other window buttons are. Are these two problems related? If this can be fixed relatively easily, I'd appreciate some instructions. Thanks.
#4 ·
Now both rear window switches in the front and the switches on the rear doors are acting up. I can make the windows go down, but they won't go up. The front windows are fine. Could the rear switches in the front be affecting the rear switches, or do I have a bigger problem? :banghead
