11 Button OBC...problem/light bulbs - BMW Forum - BimmerWerkz.com
Old 01-10-2012, 12:30 AM   #1 (permalink)
Car: 1998 BMW 323is
bpwestmoreland is on a distinguished road
I have had my car since April, and the OBC has not worked, I am slowly getting the car back together. I pulled it out and saw that a bulb was burned out, being these run in series, will one bulb being burned out make them all not work? The OBC does not light up or anything. Advice or help is greatly appreciated.
bpwestmoreland is offline   Reply With Quote
Old 01-10-2012, 02:45 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Take it apart and hunt down a blown bulb (maybe a solder-iron fix), or get another one...
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 01-10-2012, 05:18 PM   #3 (permalink)
Car: 1998 BMW 323is
That does not really help, I believe I said I found the blown bulb. I was asking if changing the bulb would help, what would have to be soldered? IDK much about these computers. Anyone with actual knowledge would be appreciated.
Old 01-11-2012, 02:15 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Sorry that I wasn't much help! - Change the bulb, or get another working unit was what I meant to say !
Eso es todo!
BMW Part Market
New Member ?
Old 01-11-2012, 04:44 PM   #5 (permalink)
Car: 1998 BMW 323is
What I was asking is if changing the bulb is a solution.
Old 01-12-2012, 02:05 PM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Ahhh, no is the simple answer as these "physical" bulbs only provide the backlight!
Your issue seems to be more sinister if you have no info showing at all, because these units are dot-matrix and should illuminate independently...
Eso es todo!
BMW Part Market
New Member ?
Old 01-13-2012, 12:21 AM   #7 (permalink)
Car: 1993 3 series
m3sleeper is on a distinguished road
yes it would, i had the same prblem with mine change the bulbs (all) of them to be safe, if any lines on the grid have gone out you will have to open it u and resolder the ribbon cable inside.
m3sleeper is offline   Reply With Quote
Old 01-13-2012, 12:24 AM   #8 (permalink)
Car: 1993 3 series
check the fuse also to be on the safe side
Old 01-13-2012, 02:43 AM   #9 (permalink)
Car: 1998 BMW 323is
Does anyone know a way to get all this apart, it seems that the bottom circuit board does not want to come out carefully. and which ribbon cable is it, there is obviously the one on the outside, is there more once I get it open.
Old 01-13-2012, 02:44 AM   #10 (permalink)
Car: 1998 BMW 323is
where is the fuse? under the hood I presume?
car light bulbs jake8000 Product Reviews 0 09-16-2010 08:00 PM
Blown Light Bulb Light Is On, But All Bulbs Work superdeadman 5-Series (E12,E28, E34, E39, E60) 5 06-23-2005 09:59 AM
Light Bulbs timmy328is 3-Series (E36) 8 12-26-2004 01:40 PM
Light Bulbs For E46 KwlAznKid 3-Series (E46, E90) 1 11-11-2004 03:32 AM
light bulbs PhiLLaY 3-Series (E36) 6 11-23-2003 12:17 AM
