02 or Knock sensors? - BMW Forum - BimmerWerkz.com
Old 08-09-2006, 09:16 PM   #1 (permalink)
toymachine595's Avatar
Car: '95 BMW 325is
toymachine595 is on a distinguished road
I have a '95 325iS and recently I upgraded my computer chip with a new one from Turner. Before I installed the chip my car ran perfect. I went to put the chip in and basically it ended up being a defective chip so I was forced to put the original one back in until Turner sent me a replacement.
Once I put the old one back in i noticed the idle would sputter every 15-20 seconds consecutively. The idle would jump from 800 rpms to 1500 rpms, the check engine light would come on for a sec, and then back down and would level itself out. I figured the the comp was re-learning itself and I cleaned the ICV as well just to make sure and still no change. I drove it until I got the new chip and after the new one was installed there was still no fucking difference.
I checked around here in the forums for a while and found nothing similar other than dirty ICV's which didn't match my case. Finally I spent about 150 something on the Peake Research scan tool and it came up with:
-Output stage, Group 1
-Knock sensor, cyl 4-5-6
-Knock sensor, 1-2-3
-Knock control test pulse
First of all I have no damn clue what an output stage is.
Plus I've talked to others on here and they said a bad 02 sensor could've thrown the knock sensor code. I don't know where to start.
If you guys could just maybe give me any feedback at all maybe you've had similar problems, I don't know. Any ways thanks.
toymachine595 is offline   Reply With Quote
540i knock sensor HELP DukeNeverwinter 5-Series (E12,E28, E34, E39, E60) 1 12-25-2005 11:00 PM
'01 530i engine knock lotsacars 5-Series (E12,E28, E34, E39, E60) 12 11-17-2005 06:15 AM
knock sensor Lunardc 3-Series (E36) 3 11-05-2005 03:26 PM
Location Of O2 Sensors J.Bassler 3-Series (E36) 7 02-04-2005 02:12 PM
change my knock sensors 95m3driva M-Series (M1, M3, M5, M6) 2 05-22-2004 06:03 PM
