Yet Another Fuel Pump Problem - BMW Forum - BimmerWerkz.com
Old 09-24-2004, 05:55 PM   #1 (permalink)
Smooth Criminal is an unknown quantity at this point
I just replaced the fuel pump in my 1991 318IS, but the engine seems like he's not getting enough fuel
The engine starts, but looks like it's gonna stall and starts shaking unless I rev it up
Is it electrical or the engine's really not getting enough fuel? Can't be the relay or else it wouldn't start at all right?
Smooth Criminal is offline   Reply With Quote
Old 09-24-2004, 08:57 PM   #2 (permalink)
BMW Lover's Avatar
BMW Lover is an unknown quantity at this point
Send a message via AIM to BMW Lover
maybe the lines are clogged? :P
^^I want this where I live.
"Drag racing a BMW is like going fishing with a hooker, it's fun but it's not what you got her for..." - M3DUDE
Manual - The transmission hated by moms/wives/girlfriends everywhere...
Member of the "I Owned my Bimmer when I was 17" Club
Member of the "10 Year Old" Club
Member of the "3 Pedal" Club
Member of the "3 Light" Club
BMW Lover is offline   Reply With Quote
Old 09-25-2004, 10:46 AM   #3 (permalink)
The only part I replaced since the pump died is the fuel pump itself
Either the new pump is the problem
Or maybe when the old pump died, it caused electrical problems
What I need to know is: can the car start if the relay is not getting 12V? Cause the car is starting fine, it just doesn't seem to be getting enough electrical or fuel power to run
Old 09-25-2004, 03:57 PM   #4 (permalink)
detour54 is an unknown quantity at this point
Send a message via AIM to detour54
What else have you checked/replaced?
<a href='http://www.e30tech.com/forum/viewtopic.php?t=8854' target='_blank'><img src='http://www.e30tech.com/pictures/e30/sig25.jpg' border='0' alt='user posted image' /></a>
detour54 is offline   Reply With Quote
Old 09-25-2004, 04:40 PM   #5 (permalink)
I've only replaced the fuel pump, nothing else
Old 09-25-2004, 06:24 PM   #6 (permalink)
[snapback]198413[/snapback]
I suggest you change your relay.
There's a good chance it could be the cause of your hard starting.
Old 09-26-2004, 07:21 PM   #7 (permalink)
I think I found the problem, the damn vacuum hoses! One of them had a little tear on one end, I patched it with duck tape until I can get some new vacuum hoses
Seems to be working ok now, hope that with all the pressure running in there the patched hose won't create any more problems...
Old 09-26-2004, 11:39 PM   #8 (permalink)
shield is an unknown quantity at this point
Replace your FUEL FILTER.
shield is offline   Reply With Quote
Old 09-28-2004, 02:13 PM   #9 (permalink)
That's ok, I'm pretty sure it's only the vacuum hose, I,m getting enough gas, I ran the car to work, the only problem is the idle when I start the car, after that it's fine
Thanks
Old 09-28-2004, 02:18 PM   #10 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
rough idle could be due to air flow my car would act like it would cut off when idle also check your intake boot for any holes and air flow sensor.
Member of got its raining(in Members Lounge) to 100, 237, 250, &amp; 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Old 09-29-2004, 03:59 PM   #11 (permalink)
Aether's Avatar
Car: 1992 Jetta GLI
Aether is an unknown quantity at this point
Send a message via AIM to Aether Send a message via MSN to Aether
And there's the obvious idle control valve.
One of my pumps is about to be replaced (at least, I think there are two), and I'm curious. Did your car always act like it needed more fuel or was it just on startup?
Four Five Six - It's on.
Aether is offline   Reply With Quote
Old 09-30-2004, 02:30 PM   #12 (permalink)
Thanks guywithblack88e30, I'll check out the intake boot and air flow sensor
And to answer Aether, my car acts weird only when I'm on neutral, once I'm geared it runs fine. But yeah, the idle when I start the car is somewhat worse than the idle once the car has been driven for a while
Fuel Pump Relay Problem mycarblows 5-Series (E12,E28, E34, E39, E60) 0 08-11-2005 09:44 PM
Fuel Pump Location Biernacki 3-Series (E36) 3 02-16-2005 02:59 PM
Fuel Pump Location Biernacki 3-Series (E46, E90) 2 02-16-2005 01:57 PM
Fuel Pump electronical Problem {NTM} 3-Series (E21, E30) 0 07-28-2004 08:08 AM
