Won't shift to reverse!! - BMW Forum - BimmerWerkz.com
Old 03-11-2011, 10:01 PM   #1 (permalink)
lokillo is on a distinguished road
Hi I bought a 325is 88 std. didn't start, slowly I have put all the pieces tougether AND Finally It starts fine. The car was parked since 2005. The car won't engage on reverse, it always engage on 1st gear. I need to replace guibo dirk & center console/ driveshaft bearing. It tumbles and sounds very bad but it engage fine on at least 1, 2 and 3. So i belive it will run OK on 1,2,3,4,5 they all engage but NO REverse what could be the situation ?? Does anyone experienced similar problem?? I just acquire tilte. I haven't drive it fast enought to shift higher than 3rd gear. any guess??
lokillo is offline   Reply With Quote
Old 03-16-2011, 06:14 AM   #2 (permalink)
anjy834u is on a distinguished road
change the alternator on ur ignition system. and for transmission issues change the gearbox fluid.
anjy834u is offline   Reply With Quote
Old 03-17-2011, 07:31 PM   #3 (permalink)
Question ehh
WTF Don't reply post just to BS and get more score on post # . If you can't add anything coherent j...
Old 04-05-2011, 07:22 PM   #4 (permalink)
mshennag is on a distinguished road
Hi, I have the same reverse problem in my 1990 e30 and still cant get to a solution, not even thinking of visiting a transmission speciallist because i know i will get ripped off and wont get it fixed...
mshennag is offline   Reply With Quote
Old 04-29-2011, 02:46 PM   #5 (permalink)
dwheeler is on a distinguished road
When you have it in 1st gear, how much side to side play is there in the shifter? If there is more than 1/2" then the shift linkage is worn. It may be worn enough to not allow it to go into reverse (or even 5th or 1st sometimes).
You can replace the linkage obviously, but I have had luck drilling out the plastic part and inserting a 1/2" tube spacer.
dwheeler is offline   Reply With Quote
won't shift to Reverse!! lokillo 3-Series (E21, E30) 0 01-10-2011 08:05 PM
NEW MATCHING SHIFT & E-BRAKE BOOT SET BMW E30 318 325, E36 shift boot customshiftboot Aftermarket Parts 0 03-01-2006 12:38 PM
323 won't go into reverse mikekit 3-Series (E46, E90) 2 11-14-2005 09:15 PM
No Reverse bad man working 1,6,7,8 - Series and Mini Cooper 5 09-11-2005 11:53 AM
BMW reverse for E39 crazy ivan Audio and Electronics 10 07-28-2004 01:34 AM
