Wiper Switch - BMW Forum - BimmerWerkz.com
Old 02-17-2005, 02:51 PM   #1 (permalink)
dsstultz is an unknown quantity at this point
I have an '83 320i. The wiper switch stopped work prior to my buying the car. The previous owner wired in a toggle switch into the wiring of the switch itself, allowing wiper operation. I have since purchased 2 different wiper switchs, abd have plugged them into the wiring harnes, thereby eliminating the orignal switch and the toggle switch. Neither one of these wiper switches has worked. Now, both of these were used parts, but it seems to coincidental that both would be broken like the original. Any ideas? Is it possible to test the switch itself? I want to get rid of the stupid toggle. Thanks
dsstultz is offline   Reply With Quote
Old 02-17-2005, 09:45 PM   #2 (permalink)
wcleafs's Avatar
wcleafs is an unknown quantity at this point
see if this helps
quote from mitchell on demand
wiper system
testing
1. unplug wiper motor connector at motor. check for battery voltage at Violet/Black
wire. move wiper switch to lower speed position. volatage should be present at Black/White wire.
2. If voltage is present and motor is properly grounded, wiper motor should operate. if motor fails to operate, it is defective. Check fuses and wiring if no votage is present.
I would check the wiper control unit to see if it is pooched. a good voltmeter and a wiring drawing will help solving this prob. used
I would send the files from this program but it has the copy function disabled and so far havent found anyone savvy enough to tell me how to defeat this option. ghead
GO LEAFS GO
wcleafs is offline   Reply With Quote
DIY Push Start Ignition El Presidente 3-Series (E36) 161 03-04-2011 03:13 PM
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Wiper And Ignition Switch Problem. Lexume 3-Series (E36) 1 02-02-2005 03:30 PM
Instrument panel switch jackinsac 3-Series (E21, E30) 4 03-16-2004 05:27 PM
Need Electrical Schematic Diagram (wiper) Tadao 3-Series (E21, E30) 2 01-26-2004 01:30 PM
