right now, my mpg gauge and coolant gauge dont work at all, but my speedo and tach fluctuate on and off...sometimes they both work, 1 works and the other doesnt, or neither work at all. anyone know what the problem is? used used
Mods:
Ireland Engineering Stage 3 springs
Bilstien Shocks/Struts
MB Motoring Rev 16x7 w/ Fuzion ZRi 205/45/16 tires
<><><><><><>&l t;><><><><>
<span style='font-size:8pt;line-height:100%'><span style='color:blue'><span style='font-family:Times'>Member of the 100,000 Miles Club</span> <span style='colorurple'><span style='font-family:Times'>Member of the 3 Pedal Club</span></span> <span style='color:red'><span style='font-family:Times'>Member of the "I'm 17 and Own a Bimmer" Club</span></span></span> <span style='color:gray'><span style='font-family:Times'>Member of the 15 Yr Old Club</span></span></span>
Links:
<a href='http://www.cardomain.com/id/tigerzrule06' target='_blank'>On Cardomain's Top 5 E30 List!!</a>
<a href='http://www.photobucket.com/albums/v305/crisby325i' target='_blank'>.:My Photo Album:.</a>
<span style='color:red'><a href='http://www.seboc.com/' target='_blank'>S.E.B.O.C. - Southeastern BMW Owners' Club</a></span>
<span style='font-size:14pt;line-height:100%'><a href='http://www.petitiononline.com/STOPCB/petition.html' target='_blank'>11564th signer of the "Stop Chris Bangle Petition"</a></span>
Originally posted by bavariankid06@Jan 27 2005, 02:45 PM right now, my mpg gauge and coolant gauge dont work at all, but my speedo and tach fluctuate on and off...sometimes they both work, 1 works and the other doesnt, or neither work at all. anyone know what the problem is? used used
[snapback]280506[/snapback]
sounds like loose wiring, take out your gauge cluster and see if its grounding out somwhere or if the plugs in the back have fallen out. and while its out replace the batteries on the guage cluster.
__________________ M42 Custom ground cams for sale PM me
264* roatation and 388 lift
Mods:
Links:
__________________ I hate: people who haven't died yet that I hate. L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc. 2000 BMW M Coupe - Dakar-II - S52 "You gotta fix the nut behind the wheel before you fix the bolts on the car"
check your fuses first, that will save you lots of trouble, and if any of them are burned out, then replace them
Originally posted by spiff325is@Jan 27 2005, 03:38 PM check your fuses first, that will save you lots of trouble, and if any of them are burned out, then replace them
[snapback]280541[/snapback]
the only problem is that the guages wouldn't work at all if the fuses were blown unless it didn't blow properly and current is jumping the gap which i guess is a possibility if you have never replaced your fuses.
Mods:
Links:
unless the batteries are leaking they prolly arent bad, you need an SI board, ive seen plenty of 20 year old cars with original SI batteries they dont go bad that often
Originally posted by e30fanm3@Feb 2 2005, 02:37 PM unless the batteries are leaking they prolly arent bad, you need an SI board, ive seen plenty of 20 year old cars with original SI batteries they dont go bad that often
[snapback]284791[/snapback]
i didn't say they went bad its just recomended that you do change them, and a leaking battery isn't the only sign of a crapped out battery, the voltage drops when they crap out too. i just changed mine 2 years ago and they were the originals, but my SI board is crapped out im pretty sure, im thinking about just taking it out caus ethose lights anoy me anyways and i do my own work so i dont want that thing to be on all the time.
Mods:
Links:
you SI board doesnt only control those lights. other things in the instrument cluster use the SI board, so taking it out will make something else not work, im not sure exactly what else it controls but its not just the lights
Mods:
Links:
