wierd engine noise (82 320i) - BMW Forum - BimmerWerkz.com
Old 10-08-2008, 09:45 AM   #1 (permalink)
82_320i's Avatar
82_320i is on a distinguished road
mine number one spark plug wire looks as if it is about to fall out when engine is running. so i tryied to push it in, as if mabye the wire was not completely seated, and it starts to make this wierd noise almost like when i push on the wire it pushes the plug father into the cylinder and the piston is hitting it....if anyone could give me some advice or something it would be a huge help. thanks
SNAKE
82_320i is offline   Reply With Quote
Old 10-09-2008, 08:37 PM   #2 (permalink)
blazein is on a distinguished road
Thumbs up noise
For starters I would pull the plugs inspect all and do a comp. test if all checks out you might be getting some premature detonation due to poor spark plug wires and errent spark so tune it up from the rotor back!
blazein is offline   Reply With Quote
Old 02-19-2009, 03:33 AM   #3 (permalink)
Car: 1982 Bmw 320i E21-M10
fj-cruizer is on a distinguished road
Sounds like Cylnder head threads are stripped.You'll need a"Helicoil"to fix that issue.Get back to me if you still need help.Do not run the Motor w/this problem...
fj-cruizer is offline   Reply With Quote
Old 02-19-2009, 12:48 PM   #4 (permalink)
If you need some new plugs, wires, or any other engine parts for your car we have some pretty good prices on parts. We also have a certified technician on phone duty you can explain noises too and he may be able to help you out 1-877-634-0063.
FCP Groton – Discount Car Parts & Auto Parts- Low Prices | Free Shipping
Best of Luck!
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
Old 02-19-2009, 04:51 PM   #5 (permalink)
JdmEuroNorth.'s Avatar
Car: 1984 BMW 318i
JdmEuroNorth. is on a distinguished road
pictures....asap..
does the spark plug move, or does the spark plug wire move?
Have you done any work with the spark plugs lately?
If the spark plug is moving around it's definatly the cylinder head plug threads are fubar'd and you'll need a helicoil or new cylinder head.
JdmEuroNorth. is offline   Reply With Quote
engine management fault wierd codes steveg 5-Series (E12,E28, E34, E39, E60) 1 08-13-2008 05:07 PM
Wierd Noise???? 98shaikh 5-Series (E12,E28, E34, E39, E60) 3 10-02-2004 11:01 AM
Help with noise on 320i se 2001 jasonsingh 3-Series (E46, E90) 0 09-08-2004 02:09 PM
Wierd clinking noise Gulelin 3-Series (E46, E90) 7 07-23-2004 10:35 AM
loud engine noise and check engine light steviebhoy 3-Series (E36) 4 06-04-2004 06:59 AM
