Whoa... - BMW Forum - BimmerWerkz.com
Old 04-15-2005, 01:20 PM   #1 (permalink)
e30driver is an unknown quantity at this point
man took a ride in my friends integra 4 door with type r moter. any ways he was shifting with out using the clutch. he said i can do it in my bmw but i amafraid to try it. so is it possible to do it in a e30 ?
by the way there was no grinding noise!
e30driver is offline   Reply With Quote
Old 04-15-2005, 01:23 PM   #2 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
[snapback]332899[/snapback]
you can do it in any vehicle. it just requires controlling the throttle when you pop in and out of gear
Old 04-15-2005, 01:28 PM   #3 (permalink)
so how would i do it? and wut do you mean by controlling the throttle? plz tell
Old 04-15-2005, 01:39 PM   #4 (permalink)
offabroadway is an unknown quantity at this point
Okay, basically what he's doing is he's bringing throttle control to the next level. When you engage a clutch, it allows you to shift gears regardless of engine speed and road speed, so long as you match the too when you let out the clutch. Syncromesh lines up the gears and away you go.
Doing this without clutching, you have to be extremely tactile with your gas and your shifter. I've only managed to pull it off once (at the time I hated manual gearboxes, but had to drive one anyways), so as you ease off on the gas, pull it lightly out of gear. (This is where you control the throttle. Letting off completely will drop the revs quick, same as when you've got the clutch in. Letting off gradually, or not completely, is the best way to match the revs quick and not damage anything) Lean on the indent of the gear you're heading to next, but don't engage it until the revs fall to the correct point to match your road speed (you lean on it so the syncromesh gets spinning and ready to help you engage the gear without ripping the teeth off your gears) and then at exactly the right moment, pop it down (or up, wherever you're going) into gear.
Any tranny with syncromesh can do it. If you're good, you can get some really good performance out of this (less slippage/loss from the clutch). If you screw it up, you can slowly destroy the transmission. That whole procedure takes a mere second, if less, to do. Practice makes perfect, but if you get grinding noises, get on the clutch, fast.
Good luck!
<img src='http://www3.telus.net/drewdlespace/bmw/banner.jpg' border='0' alt='user posted image' />
Changed the car's name, now it's - Roxanne -1985 325e
offabroadway is offline   Reply With Quote
Old 04-15-2005, 01:43 PM   #5 (permalink)
cool okay thanks for the info
i ll try it some time today
Old 04-15-2005, 02:38 PM   #6 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
careful thou i have done this in my car when i was pissed by acciendent it really drops ur time lower say if you were at a track. i beat a 68 mustang doing it this way when i was pissed i beat him by like a car & 1/2
Member of got its raining(in Members Lounge) to 100, 237, 250, &amp; 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Old 04-15-2005, 08:11 PM   #7 (permalink)
okay i tried it but it wouldent go out of first with out grinding!!(did only twice) got any sugestions on what iam doing wrong?
Old 04-15-2005, 09:15 PM   #8 (permalink)
jze325i's Avatar
jze325i is an unknown quantity at this point
Good luck!
[snapback]332910[/snapback]
Very nicely put my freind, could not have said it better myself... To do this you really have to UNDERSTAND what is going on inside there...
jze325i is offline   Reply With Quote
Old 04-15-2005, 09:21 PM   #9 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
bad bad bad idea! Don't even attempt it anymore unless you want to start replacing components!
jrhaile is offline   Reply With Quote
Old 04-15-2005, 09:33 PM   #10 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
Ive done it in my moms volvo, kinda by accident when i was first learning 5 speed... i think it would be harder in my car just because the gearbox is notchier.. if that makes sense.
i doubt il ever try to do it in my car.
catalyst. is offline   Reply With Quote
Old 04-15-2005, 09:40 PM   #11 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
if you can match the RPM's correctly with the correct throttle, it can be done. in my dads old VW Rabbit, the clutch went out, and he got home fine, and when he would come to a stop, he'd have to shut the car off, and put it in first then start it in first with gas to go.
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 04-15-2005, 09:45 PM   #12 (permalink)
jze325i's Avatar
It is a nice thing to "know" hwo to do to get you out of a jam if need ba, but there really is no point otherwise!!!
Old 04-15-2005, 09:46 PM   #13 (permalink)
VeLoCiTy318's Avatar
VeLoCiTy318 is an unknown quantity at this point
lol my friend did this in his integra awhile ago and I was like
dont think I'd risk trying it on my bimmer tho
<img src='http://i5.photobucket.com/albums/y196/velocity318/test2.jpg' border='0' alt='user posted image' />
Kenwood KDC-MP822 h/u, H&amp;R race springs, Bilstein sport shocks, Rondell 17x8 wheels, Toyo proxes 225/45, TMS camber arms, rolled rear fenders, smoked corners, smoked sidemarkers, smoked taillights, Cosmo cold air intake, ///M pedals, clutch stop, parking light delete, license plate delete, black roundel overlays, tint
VeLoCiTy318 is offline   Reply With Quote
Old 04-15-2005, 09:51 PM   #14 (permalink)
jze325i's Avatar
[snapback]333205[/snapback]
Learn on his Integra, that way you'll know how to do it if you ever NEED to
Old 04-16-2005, 09:19 AM   #15 (permalink)
Trob is an unknown quantity at this point
Originally posted by jze325i+Apr 15 2005, 08:51 PM--><div class='quotetop'>QUOTE(jze325i @ Apr 15 2005, 08:51 PM)</div><div class='quotemain'><!--QuoteBegin-VeLoCiTy318@Apr 15 2005, 10:46 PM
lol my friend did this in his integra awhile ago and I was like*
[snapback]333208[/snapback]
[/b][/quote]
I just spent 1800 on a new trannie..I'm not doing anything to take the chance of having to do that again! ghead
91 BMW 325 IX
BLACK
2 DOOR
5 SPEED
THE MORE RARE IT IS THE MORE IT COSTS TO FIX!
95 BMW 325 IS
GREEN
2 DOOR
5 SPEED
LET THE MODS BEGIN
Trob is offline   Reply With Quote
whoa e36_m3_Turbo North West 40 02-14-2006 07:36 PM
whoa mustang whoa skawful Video Vault 1 07-06-2004 09:18 PM
WHOA look at this kamikazinyc 3-Series (E36) 22 12-09-2003 08:49 AM
