white smoke when warming up - BMW Forum - BimmerWerkz.com
post #1 of 16 (permalink) Old 05-30-2004, 04:12 PM Thread Starter
320ie30 is an unknown quantity at this point
alright i have issues with my motor..when i start it up in the morning it smokes white like billows out i can't figure out what it is..i checked all the obvious signs of a BHG and everything looks ok...it also idles at 1500 rpm i tried to adjust the idle and that didn't work..i will do a compression check just wondering if you guys had some ideas
320ie30 is offline
post #2 of 16 (permalink) Old 05-30-2004, 05:06 PM
jalupinyah is an unknown quantity at this point
Yah my 3000gt does that since i took off my cat does it do it when u take off from a light maybe your cat is going bad
jalupinyah is offline
post #3 of 16 (permalink) Old 05-31-2004, 02:48 AM Thread Starter
well it also does it when i like rev it hard from idle..but when i am driving as far as i know it's fine...my friend told me he didnt see any smoke when we were drifting the other day
320ie30 is offline
post #4 of 16 (permalink) Old 05-31-2004, 07:16 AM
CiscoKid's Avatar
wqhen waqs the last time you changed your oil? make sure you put the right viscosity in.
CiscoKid is offline
post #5 of 16 (permalink) Old 05-31-2004, 08:59 AM
BimmerKris's Avatar
BimmerKris is an unknown quantity at this point
if it's white smoke, cahnces are you have a crack somewhere in the block and that is coolant burning off, do you have to keep filling you coolant?
<img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='
target='_blank'>
100% thrash your face off metal
BimmerKris is offline
post #6 of 16 (permalink) Old 05-31-2004, 09:29 AM
Trob is an unknown quantity at this point
If your burning coolant you would definitly be able to smell that in your exhaust and it would continue to come out when your driving. Not just when you first fire it up.
91 BMW 325 IX
BLACK
2 DOOR
5 SPEED
THE MORE RARE IT IS THE MORE IT COSTS TO FIX!
95 BMW 325 IS
GREEN
2 DOOR
5 SPEED
LET THE MODS BEGIN
Trob is offline
post #7 of 16 (permalink) Old 05-31-2004, 12:01 PM
BimmerKris's Avatar
not nessasarilly, once the block heats up, the crack will close if it is small enough, ive seen it happen before. if it is burning oil, the smoke would be blue
<a href='
target='_blank'>
post #8 of 16 (permalink) Old 05-31-2004, 02:18 PM Thread Starter
well the guy changed the radiator and water pump on it,and i think he didn't put enough water in it to begin with so i filled it up again and it's been fine.. i kinda smell a gasy smell in it in the morning...it was low in oil when i got it so i put some more in it...i will change it after i get back from being deployed and see what happens...i hope it's not a crack or blown head gasket...this will make number 3 in a row i've bought with a BHG and noone told me it had a blown head gasket on any of them...uggh my luck
320ie30 is offline
post #9 of 16 (permalink) Old 05-31-2004, 07:46 PM
Kevin325i's Avatar
Sounds just like moistures evaporating out of the exaust system. Is it pretty damp where you live?
Kevin
Kevin (President TBEA)
Kevin325i is offline
post #10 of 16 (permalink) Old 05-31-2004, 11:50 PM Thread Starter
i live in england, it doesn't do that on my friend bimmer so i don't think it's that
320ie30 is offline
post #11 of 16 (permalink) Old 06-04-2004, 12:36 AM Thread Starter
also an update on it, seems like it's getting worse....i tried to smell it to see what it smelled like but it didn't smell like much of anything...why does this always happen when i get the car grrrr...
320ie30 is offline
post #12 of 16 (permalink) Old 06-04-2004, 05:32 PM
Fox
Moderator
Its most likely your rings. Oil is seeping down and when the engine is cold the rings are smaller and oil burns past them. When the engine warms up the rings expand and have a better seal.
Fox is offline
post #13 of 16 (permalink) Old 06-06-2004, 03:29 PM Thread Starter
ok i looked in where my coolant goes and it was hella low...i look under the car and there is no cat to be found grrr...
320ie30 is offline
post #14 of 16 (permalink) Old 06-08-2004, 05:51 AM
drwambo is an unknown quantity at this point
Unfortunately, it sounds like a head gasket to me. Probably seals itself up when the block heats up.....
drwambo is offline
post #15 of 16 (permalink) Old 06-08-2004, 03:11 PM Thread Starter
how hard is it to replace...anyone ever done it? How many hours? I have replaced the head gasket on a supra before and i remember it was just alot of hoses and wires to take off
320ie30 is offline
White smoke comming out of engine bay kc740i 1,6,7,8 - Series and Mini Cooper 8 12-03-2005 10:10 PM
325i white smoke and idle problem puppie 3-Series (E36) 3 10-22-2005 07:57 AM
White Smoke Coming Out Of A/c in_si1ence 3-Series (E36) 9 08-22-2005 01:22 PM
540i And White Smoke HardStep 5-Series (E12,E28, E34, E39, E60) 3 02-22-2005 10:12 AM
