| nope.......not on the 318i.........it should be on the driver's side up in front by the starter.
and if she is bogging down on freeway occasionaly, i would suspect the fuel pump cutting out, but here again you need to test it.
__________________ sexually assault a member of the VW community? if you belong to dubdojo or swov.org they will gladly circle their wagons and support you. |
