Wheels Offset? And Center Bore? - BMW Forum - BimmerWerkz.com
Old 12-01-2004, 07:44 PM   #1 (permalink)
Halfnhalf325 is an unknown quantity at this point
Do you guys know if 40mm Offset and Center Bore: 73.1mm would work on e30's.
Halfnhalf325 is offline   Reply With Quote
Old 12-02-2004, 07:25 AM   #2 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
offset works fine im not sure about the center bore...i have found that almost anything 4X100 fits...the BMW centerbore is smaller than on hondas and other ricers... so it should fit...unless its an odd size...what are the rims off of?
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 12-02-2004, 09:38 PM   #3 (permalink)
you have to give the width of the wheel when asking about offset; however, if the wheel is 7" wide or wider it most likely wont fit. the e30 center bore is 57.1mm so the wheels will fit on the hub with hub centering rings, but it may give you steering wheel shimmy and vibration.
Old 12-23-2004, 12:44 PM   #4 (permalink)
you have to use centering rings on the wheels. the 40mm offset will not work on the front but it will on the back, you will have to use spacers all the way around to make it look right. you are better off finding a set with the correct offset. the centering rings will not effect the ride, but not using them will.
jake
Fs: 4 Bbs Ch Motorsport Wheels mymazda62003 Wheels and Tires 1 08-15-2005 04:53 PM
Rim Question BeemerMan 5-Series (E12,E28, E34, E39, E60) 4 01-07-2005 07:54 PM
Wheels questions postrio 3-Series (E46, E90) 15 10-12-2004 01:18 PM
FS: New BBS LM wheels 18x8 5x120 BMW Replica EurocRAzy Classifieds Sell & Buy 0 06-24-2004 01:37 PM
4 BMW Double Spoke Style 53 Wheels / Rims - DEAL Domino Classifieds Sell & Buy 1 06-23-2004 11:47 AM
