Wheel bearing replacement - BMW Forum - BimmerWerkz.com
Old 08-10-2006, 09:29 PM   #1 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
Ok. So I think I've gotten the hesitation worked out on my bargain project, now on the the next pressing issue! It has a terrible high pitched grinding sound coming from the rear. It almost sounds like the rear calipers dragging like they do if a car has been sitting for a while and the rotors rust up. Kindof a scratchy harmonic ringing. I know it's in the drive train as it is not dependant on engine speed or breaking but on wheel speed. I checked the diff fluid level and it was pretty low so I put some Lucas 90w in it hoping it had a dry output shaft bearing or something. Still noisy. I've never had a bearing issue with one of these cars. Does this sound like a wheel bearing to anyone? I've heard plenty of bearing noises but none quite like this one. Haven't really put a whole lot of diagnostic effort into it yet, just thought maybe there was a common thing with these cars and I could save some time with a hint! Also it has a bad strut and being as it is for my college bound bretherin I need a cheap fix. If anyone has good used set let me know!
DIRTE30 is offline   Reply With Quote
Old 08-10-2006, 09:46 PM   #2 (permalink)
Car: Opening soon:
Reach up and grab the yoke and see if you have movement. Next pull off your rear rotors and check the condition of your E-brake shoes, it's common for the pad to fall off the shoe and make all kinds of hoakey noises.
Old 08-11-2006, 02:29 PM   #3 (permalink)
DIRTE30's Avatar
I'll try that but I've pulled the e brake while rolling to see if the noise changed, but no. So I don't think it's ebrake related. Never know though, I'll try that tonight as I was gonna take the wheels off anyhow to see what I can see. Thanks buddy.
replacement steering wheel -oem mikehoff 3-Series (E46, E90) 4 02-22-2006 06:58 PM
wheel bearing? bob318 3-Series (E36) 3 02-21-2006 12:15 AM
Rear Wheel Bearing, Replacing victorgallas 3-Series (E36) 0 04-06-2005 06:59 AM
Wheel bearing screwed Turbodefrost 3-Series (E36) 0 09-06-2004 11:19 PM
A question for 528i front wheel bearing bigbowl 5-Series (E12,E28, E34, E39, E60) 2 08-06-2004 05:33 PM
