What kind of Fuel Pump does the 325I have? - BMW Forum - BimmerWerkz.com
Old 04-04-2011, 11:46 AM   #1 (permalink)
Car: 1987 BMW 325I
Tabatha is on a distinguished road
My car, 1987 325I, is up at the shop now, but to get an idea of how much I will be spending I would like to know if it has and internal or external fuel pump or both.
I can get one at Autozone for $160.00
The shop is going to charge me $250.00,plus labor ($400.00 total)
If it only has one I want to save myself money because I don't have a lot of it.
Thanks!
Tabatha is offline   Reply With Quote
Old 04-07-2011, 08:02 PM   #2 (permalink)
Mr.Bimmer is on a distinguished road
Well, not sure if this helps but I have a 82 733i and it has both external and internal.
Mr.Bimmer is offline   Reply With Quote
Old 04-09-2011, 10:17 PM   #3 (permalink)
TravisW is on a distinguished road
Thanks!
go up under the rear of the car and look for the fuel tank. if there is an external pump it will be on the drivers side up under the rear seats on the frame rail. just follow the fuel lines from the tank. More than likely you'll just have an in tank fuel pump. Pop the rear seat out and it should be on the passenger side. bunch of little bolts hold it in place. nothing too difficult. if you can do a tune up you can swap out the pump. buy the entire assembly. make sure to put some fuel system treatment in the tank after you're done. That should help burn off any small amounts of dust/dirt particles shall any get in the tank while ur putting th enew pump in.
if you were near memphis id do it for ya for a case of beer good luck
TravisW is offline   Reply With Quote
Old 05-11-2011, 03:43 PM   #4 (permalink)
squirrl_98 is on a distinguished road
Fuel Pump
Tabatha Hey hun what is the month of your car? If you go look at the door jam it will tell you. Then if you go to RealOEM.com Online BMW Parts Catalog under the archive selection on the left and tap E30 you can go in there and check all that apply to your car to see what it has and also helps to see how to take stuff apart. 87 is the split year and the year they went to the intank pump only later half, I know I have an 9/88 325 cabrio. I'm at Dobbins so give a holler. My bud has a few of the used ones and the boys at Higgin Botham and Assocs. all race Bimmers on the weekends tons of knowledge right here. They said you can also get parts from rmeuropean.com.
squirrl_98 is offline   Reply With Quote
325i 1994 Bmw - Possible Fuel pump problem! Spook 325i 3-Series (E36) 20 08-15-2011 11:28 PM
fuel pump advice -87 325i crabbdaddy 3-Series (E21, E30) 8 03-26-2011 05:25 PM
87 325i fuel pump relay location??? soooooawesome 3-Series (E21, E30) 4 06-12-2009 08:58 AM
1989 325i fuel pump jwells21 3-Series (E21, E30) 2 05-20-2008 10:45 PM
Fuel Pump Relay Location On 325i Brian3251 3-Series (E36) 8 01-16-2005 03:10 PM
