what if ? intake ? - BMW Forum - BimmerWerkz.com
Old 11-06-2005, 12:18 AM   #1 (permalink)
j123crx is an unknown quantity at this point
what if ? intake ?
if you ran a cone filter directly to the engine and bypassed the mas what would happen ? leaving the mas connected but not interupting the airflow. would this work, you would need to get cold air to the mas for best function right ? : B)
j123crx is offline   Reply With Quote
Old 11-06-2005, 05:32 AM   #2 (permalink)
Car: 1984 325e
driftin325s is on a distinguished road
Send a message via AIM to driftin325s
well idk but wouldnt it be better if u got the cone filter got rid of the air box and put intake piping from the cone to the maf sensor and took out the left high beam because if u got an air filter right on the engine i dont think that there would be enough air getting that far to the cone but idk im just expressing my opinion
<a href="http://www.royal-flushapparel.com" border=0><img src="http://www.royal-flushapparel.com/images/banner-lg.gif" /></a>
driftin325s is offline   Reply With Quote
Old 11-06-2005, 05:47 AM   #3 (permalink)
Car: 1984 325e
Old 11-06-2005, 10:21 AM   #4 (permalink)
1985_318i's Avatar
1985_318i is on a distinguished road
The best thing to do is, yes remove the air box and run piping to closer to the headlights, attaching the filter here. Then use aluminum sheets and tin snips from Lowes, etc and build a heat shield to prevent the intake from pulling in any of the hot engine air. Removing the high beam would only help.
1985_318i is offline   Reply With Quote
Old 11-06-2005, 08:04 PM   #5 (permalink)
i've got my highbeams in the center holes and have a mesh over the headlight hole, the cone sits right behind the hole-so i already have that covered, if you had a straight pipe from the cone to the engine (moving the mas off to the side) then you would have direct air flow to the TB ? also i could line up the cone better behind the hole if i was using an aluminum pipe or PVC.
Old 11-07-2005, 08:11 AM   #6 (permalink)
1985_318i's Avatar
Use the PVC, but don't bypass the maf sensor. If you do it will run like dirt. This sensor lets the engine know it is getting enough air. I changed the air filter on my 1985 318i recently and did not completely reattach the maf to the throttle body. It would hardly start, let alone it ran like crap. Just pipe the cone into the maf w/pvc and you still need a heat shield.
And how 'bout a pic?
Old 11-07-2005, 08:32 PM   #7 (permalink)
gotcha. good advice, i wasn't sure if that would function or not, i know unplugginf the mas will kill it.
Idle Problems, Intake Service Bulletin? rhansen162 5-Series (E12,E28, E34, E39, E60) 1 03-06-2005 07:18 PM
GruppeM Intake woobiee Product Reviews 20 08-20-2004 01:34 AM
porting and polishing intake manifolds nycbmw325is 3-Series (E36) 14 07-22-2004 01:52 PM
2004 E60/530i Cold Air Intake - HELP howiedog 5-Series (E12,E28, E34, E39, E60) 2 07-13-2004 01:12 PM
Intake install ? and sparkplug ?? Eggrolled211 3-Series (E36) 6 08-11-2003 05:16 PM
