Weird Result From Compression Test. - BMW Forum - BimmerWerkz.com
Old 04-15-2005, 09:00 PM   #1 (permalink)
joshh is an unknown quantity at this point
So I bought a parts car yesterday for $340.00. It ran for a bit so I know it runs.
I pull the main fuse, pull all the spark plugs, thread in the tester, push the peddle all the way down and turn the car over. The result....cranking but absolutely no compression to the #1 cylinder. I mean none. I do however get a gas smell.
I would just worry that the #1 cylinder is totaly shot but I just did the same exact commression test to my other E-30 right before this. I'm a bit lost as to why the first car has a gas smell and the second didn't at all. And why there would be no commpression to the cylinder.
Thanks in advance.
Finally pulled the M50 from the donor car.
joshh is offline   Reply With Quote
Old 04-15-2005, 09:13 PM   #2 (permalink)
jze325i's Avatar
jze325i is an unknown quantity at this point
I even had my daughter look and make sure the belt wasn't just slipping on the pully.
Thanks in advance.
[snapback]333168[/snapback]
Perhaps the timing belt slipped a tooth?? How does it run, is it like "skipping" when it runs?
jze325i is offline   Reply With Quote
Old 04-15-2005, 10:06 PM   #3 (permalink)
Even if it skipped I tooth, I would think there would still be compression. 2 teeth off is fine with this motor. 3 teeth = valve damage.
Old 04-16-2005, 08:24 PM   #4 (permalink)
If anyone cares heres what I found.......
I remember reading in the Bentley that the older cam gears were recalled and replaced with stronger ones. Well by the looks of this one compared to the one on my other E-30, this is the old cam gear.
Well the cam gear had broke at the base and was just spinning without turning the cam. So the bottom end was turning and the head was not.
The result....at least 2 bent valves.
Just a warning to all you without the newer cam gear.
Whats cylinder compression supposed to be on 89 325i Slow325i 3-Series (E21, E30) 2 10-29-2005 06:41 PM
Dead And 30 Lbs Compression - Now Running?!? E36_318_is 3-Series (E36) 6 04-07-2005 08:18 PM
M3 Compression Test And Cooling System MadBMW M-Series (M1, M3, M5, M6) 0 03-10-2005 09:47 PM
Bad Compression In The 6th Cylinder the24case 3-Series (E46, E90) 6 12-30-2004 10:07 AM
BMW WilliamsF1 Team-Ho-Pin Tung Jerez Test Stacy540i Bimmer Talk/Motorsports Talk 0 12-11-2003 09:29 PM
