Water??? - BMW Forum - BimmerWerkz.com
Old 01-11-2005, 12:58 PM   #1 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
Thumbs up
ok so i decided to drive the Beemer today since its finally not raining here so i i drive a little and i starts to here the ocean i get home i look in trunk and theres water almost to the top where battery is and jack and a little puddle on top of carpet where spare is the rest of the carpet in there is pretty much dry. then i look in cab and theres a puddle of water right behind passenger seat dry behind drivers seat and in front seats just behind passengers seats.
any ideas how this is happening and how to get rid of the problem??????????????
Member of got its raining(in Members Lounge) to 100, 237, 250, & 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Old 01-11-2005, 01:07 PM   #2 (permalink)
Bimmin'88's Avatar
Bimmin'88 is an unknown quantity at this point
[snapback]268970[/snapback]
I can share your misery.......my passenger side was POND this morning....just finnished vacuming it all out.
I think mine is the sunfoof.
As far as the battery side of your trunk.....I have no idea! The other side.....antena seal.
Good Luck
Member: "Ran from a cop and got away" Club
Member: "Old Guys Rule" Club
Bimmin'88 is offline   Reply With Quote
Old 01-11-2005, 01:10 PM   #3 (permalink)
i don't think its mine sunroof only cause i have drove car in hard rain before and nothing. antena seal could be that side thou. thanks dude
any other ideas??
Old 01-11-2005, 01:38 PM   #4 (permalink)
RealBMW 02's Avatar
RealBMW 02 is an unknown quantity at this point
Send a message via AIM to RealBMW 02
i had the same problem...got in my car after a hard rain during school one day...started to drive and heard sloshing behind my passenger seat....i had a good four inches of water.
my problem turned out to be bad window seals that allowed water to first run into my trunk, and then into the cabin. It got into the cabin through the same whole the fuel lines run....i would check there. My lines run right down the right side of the back seat. might want to check that out.
good luck
<img src='http://files.unitedbimmer.com/ub.c/RealBmw%2002/Sig_ver2.jpg' border='0' alt='user posted image' />
1970 - 2002
Proud Memeber: 30+ year old car club
RealBMW 02 is offline   Reply With Quote
Old 01-12-2005, 12:18 PM   #5 (permalink)
ok here is pics of the water in the places i listed in first post(both sides of trunk water behind passenger seat,& under rear seat)
Member of got its raining(in Members Lounge) to 100, 237, 250, &amp; 300 pages club...
Old 01-12-2005, 12:20 PM   #6 (permalink)
under rear seat
Old 01-12-2005, 12:26 PM   #7 (permalink)
good luck
[snapback]269013[/snapback]
only thing don't the fuel lines on my car run differently then your car you have a in-line fuel pump and i have a in tank fuel pump right?
Old 01-12-2005, 12:46 PM   #8 (permalink)
Red_Rocket's Avatar
Location: Coeur D' Alene, ID : Tuscaloosa, AL : Atlanta, GA
Car: BMW 325
Red_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really nice
Send a message via AIM to Red_Rocket
theres some pennies in there......yea i opened my trunk onetime after rain and one side had a big puddle i checked te rubber on the door and stuff but there was no damage...dunno what it is
Red_Rocket is offline   Reply With Quote
Old 01-12-2005, 05:58 PM   #9 (permalink)
BMW@JMU's Avatar
BMW@JMU is an unknown quantity at this point
i have similar problems whenever it rains hard or i wash my car; although my trunk just gets moist. i'm still not sure what it could be because the trunk gasket seems to be in good condition. i've also heard of the seal around the tail light leaking or possible a crack in a tail light. i guess try checking those out.
-1985 325e - 5000 RPM's of Fury
BMW@JMU is offline   Reply With Quote
Old 01-13-2005, 02:52 PM   #10 (permalink)
ye12 is an unknown quantity at this point
I don't know if this solution will be an answer to your trunk leak problem, but my battery compartment was quite wet and after looking for the leak, I found that the rubber flapper that vents the air out of the trunk was not sealing properly. After straightening it by hand, no more leaks. The vent sits right next to the battery.
ye12 is offline   Reply With Quote
Old 01-14-2005, 11:15 AM   #11 (permalink)
crazyinkc is an unknown quantity at this point
My trunk was getting wet when it rained and I found my left taillight gasket to be shot. When I pulled the taillight out, I used clear silicone on the gasket on both sides and my trunk has been dry ever since.
crazyinkc is offline   Reply With Quote
Old 01-16-2005, 11:25 PM   #12 (permalink)
Bimmin'88's Avatar
I think I just figured mine out!!!
No RAIN= No Water in my car!!
Haven't had water problen for three days!!
Member: &quot;Ran from a cop and got away&quot; Club
Member: &quot;Old Guys Rule&quot; Club
Old 01-17-2005, 01:18 AM   #13 (permalink)
Speedy-325is's Avatar
hey, if you want, i have all the window seals and trunk seals from my 91 318...
come up to ventura and ill give them to you for a small $20, manditory donation.
Mark
Old 01-17-2005, 03:18 AM   #14 (permalink)
maybe dude im gonna check eclogy soon to see how much
Old 01-17-2005, 11:21 PM   #15 (permalink)
RealBMW 02's Avatar
you should get that water out of there asap... you will rust the shit out of your body if you leave it there. I had to use a electric water pump and sponge to get all of the water out of my car when I had that problem
1970 - 2002
Coolant precision0904 3-Series (E36) 12 02-09-2011 10:15 PM
Coolant Question dvmotorsports 3-Series (E36) 6 06-10-2005 09:31 PM
water under backseat??? needhelp 3-Series (E36) 4 03-22-2004 04:51 AM
Water in my car!!! Tknojnky 3-Series (E46, E90) 14 01-21-2004 07:43 PM
