vibration question - BMW Forum - BimmerWerkz.com
Old 10-19-2009, 07:33 AM   #1 (permalink)
Car: 87' 325i 5spd
Docho is on a distinguished road
vibration question
Good morning everyone,
I have a question in regards to a vibration that seems to be coming on around 75MPH and increases with an increase in speed. I woul like to know if any of you have experiened this and what component might be suspect in causing this. I.e. Wheel balance, wheel bearing, driveshaft imbalance, bushings. Any sugestions would be appreciated. Thankyou all in advance for your help once again
Docho.
Docho is offline   Reply With Quote
Old 10-19-2009, 08:42 AM   #2 (permalink)
hmuchmo1 is on a distinguished road
Increasing vibration with increasing speed can be hard to diagnose. Because it can be an unbalanced tire, worn tie rods, worn or blown struts, warped/bent rim.
but some questions to help diagnose would be.
do you have aftermarket wheels?
Did you recently get a tire replaced?
any suspension work recently? if no when was last time it was serviced?
hit a really bad pothole recently?
can you push down on the car with your hands at does the car spring back up and stop? or does it keep bouncing a little?
hmuchmo1 is offline   Reply With Quote
Old 10-19-2009, 09:33 AM   #3 (permalink)
Car: 87' 325i 5spd
I just recently got the car. I did notice a vibration in the front end when I first got the car a couple weeks back. I checked tire pressure and rotated the tires. The vibration decreased quite a bit. Now seen to be coming more from the rear and with increasing speed as previously stated. I'm tending to lean toward a tire imbalance issue. However I am new to BMWs. What do you think?
Docho
Old 10-19-2009, 09:43 AM   #4 (permalink)
Having the wheels checked for balance would seem to be the first step.
Old 10-21-2009, 02:05 AM   #5 (permalink)
Car: 1987 320i Cabrio, with M3 bodykit
87ragtop320 is on a distinguished road
Send a message via Yahoo to 87ragtop320
i had the same problem with my 87 320i, check all the bushings for the front suspension when you can get it up on a lift, they should not be cracked, and if the are, replace them, its really easy job to do
87ragtop320 is offline   Reply With Quote
Old 10-21-2009, 06:25 AM   #6 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
carguy13 is on a distinguished road
+1 for the balance, before you change a bunch of stuff and spend a lot of money.
carguy13 is offline   Reply With Quote
Old 10-21-2009, 07:04 AM   #7 (permalink)
Car: 87' 325i 5spd
Yea, thanks fellas. I will start with the wheel balance and take it from there.
Old 10-21-2009, 07:06 AM   #8 (permalink)
Car: 87' 325i 5spd
Thanks fellas. I will start with a wheel balance.
Vibration PANA 5-Series (E12,E28, E34, E39, E60) 4 02-03-2009 08:42 PM
Vibration from below....... luckycat 3-Series (E21, E30) 2 10-24-2005 04:01 PM
Ya...another Vibration Question... doughnutboy 3-Series (E36) 3 06-02-2005 01:09 PM
Vibration e36surge 3-Series (E36) 3 05-17-2005 11:56 AM
Vibration fizzy 5-Series (E12,E28, E34, E39, E60) 0 04-05-2004 09:15 AM
