VDO check light flashing - BMW Forum - BimmerWerkz.com
Old 05-31-2004, 12:40 PM   #1 (permalink)
Le_max is an unknown quantity at this point
My "VDO check light" flashes. This appened after I replaced the instrument cluster with a new (used) one. I have a 325i 1989, replaced it with a 325is 1988. The old one did not work properly but the check light was not flashing.
what does it mean?
Le_max is offline   Reply With Quote
Old 05-31-2004, 01:00 PM   #2 (permalink)
even if everything is good, the check light will flash at start-up until you hit the brake pedal to check the brake lights. if the check panel (on the ceiling) indicates a fault such as oil level, lights, etc... it will start to flash again or continue flashing to let you know of a potential problem until you hit the "check" button on the check panel.
Old 05-31-2004, 01:03 PM   #3 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
yup
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 05-31-2004, 01:36 PM   #4 (permalink)
ok, thanks
P.S. I know that I look like a noobi but I swear that I know how to use a wrench!
Old 05-31-2004, 08:09 PM   #5 (permalink)
Old_School_Bimmer's Avatar
Old_School_Bimmer is an unknown quantity at this point
Send a message via MSN to Old_School_Bimmer
Make sure all the bulbs work
Old_School_Bimmer is offline   Reply With Quote
Old 05-31-2004, 08:23 PM   #6 (permalink)
spiff325is's Avatar
Car: 00 M Coupe
was the car on?
lol
Old 06-01-2004, 06:19 AM   #7 (permalink)
drwambo is an unknown quantity at this point
On startup, the system goes through a check. THe last item it checks is the brake system. THe light in the Information center and flashing VDO will go out as soon as you hit the brake pedal. This is part of the system's test (checking the switch I guess). Mine does it too.
drwambo is offline   Reply With Quote
Old 06-01-2004, 03:42 PM   #8 (permalink)
Halon is an unknown quantity at this point
Send a message via AIM to Halon Send a message via MSN to Halon Send a message via Yahoo to Halon
My car has the "inspection" light on, and its sort of confusing to me, because the car handles well, has no problem with responsivness, and ... blah. I'm just wondering if I should really worry and take it to the bmw dealer or something and get reamed real good, or if I can ignore it. The car sounds alright, but I was trying to find out whats up with the light. Sometimes in the dark it looks like, could be wrong, but looks like it may be lit up on the little bars underneath of the "inspection" light all the way to the red one. Do they each mean something different, or do they each add up to mean something worse? Haha, shit. I need to get this figured out.
[edit]
Halon is offline   Reply With Quote
Old 06-02-2004, 11:49 PM   #9 (permalink)
e30 dude is an unknown quantity at this point
1. is it bad to step on the break before/during starting the car?
2. as far as i know, the inspection lights are just reminders to have your car checked. its next to useless, if you're meticulous about taking of your car, which i am. so i just covered it up, as its annoying the hell out of me.
e30 dude is offline   Reply With Quote
check engine light Kubna 5-Series (E12,E28, E34, E39, E60) 7 06-28-2004 02:00 AM
Warning! Cashier's Check Fraud L337E46 Classifieds Sell & Buy 2 03-06-2004 03:04 PM
check engine light and check light Scarface 3-Series (E36) 3 06-03-2003 08:31 AM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
